V10 PI head swap issues
You'll have to forgive me for probably posting something twice...
First time posting...
Just finished a 2000 PI Head and intake swap on a 99 F-350.
Heads were surfaced, valve job, and helicoils installed. Also custom tune
Ran great for 5 days then developed a miss. Melted Motorcraft Platnium plugs.
Installed NGK TR6 plugs and pulled and reinstalled tune with 4% more fuel and -2 timing. Ran good for one day, now miss has returned at low RPM and under down hill load with zero throttle. Miss isnt present at higher RPM (over 1500-1800).
Driving me crazy, so I joined hoping for some help...
Any suggestion would be appreciated
try loading up a factory tune and see how she runs. you've got a programming issue it sounds like
also, the COP's on the mod motors are very very very...picky...Use OEM Motorcraft only. Pull 1 at a time and see if the miss moves. Then only replace that one.
Checked on wide band today. 12's from 1/2 throttle to full and 14-16 from 1/2 to idle. Alittle lean at low rpm but ok. Changed tune, added fuel and returned low rpm range to 0 timing. After a few miles, miss returned intermitently. Maybe crap coil packs after all?
customk2500
Dec 12, 2012 11:05 AM
tankhokie
Jul 8, 2004 10:44 PM
