Sponsored by: Real Truck
Torque Bind?
Old Aug 31, 2007 | 04:41 PM
Jenks Reid's Avatar
Jenks Reid
I finally figured out that front hubs are not fully unlocking which accounts for the bump, bump, bump while steering in tight turns. The hubs are not fully unlocking because of a vacuum problem (I think) which I have now learned has also effected air flow in the heating/cooling system. Bottom line is that right now air ONLY blows out of the defrost vents on top of the dash and not out of the front or down at my feet, regardless of where I select on the A/C control
I replaced a $45 dollar vacuum module (don't know the technical name) two times in the past 10 days and both times it temporarily fixed the air flow problem. But as soon as I switch to 4x4 the airflow problem returns AND the front hubs are still partially locked.
The problem lies in the $45 vacuum module. As of now we don't know if we are permanently damaging the part when we switch to 4x4 OR if there is a valve or something inside the module that is not electronically opening or closing in order to control the 4x4 AND air flow. Anyone got any good ideas?
Old Aug 31, 2007 | 11:29 PM
aldridgec's Avatar
aldridgec
Originally Posted by redford
To experience this for yourself, lock your hubs without engaging the transfer case, crank your steering wheel to full lock left or right and drive forward slowly.
You'll feel the binding of the U-joints on the drive axle.
Symantics I think. I wouldn't call this torque bind, just typical u-joint issues from the high angle. I consider torque bind when it is hard to move forward while turning sharply on a surface without low traction an in 4x4
Old Aug 31, 2007 | 11:34 PM
aldridgec's Avatar
aldridgec
You need to check the system for leaks. The best way to do this is with a hand held vacuum pump. YOu can start at the solenoid an work your way to the hubs. If the vacuum holds then the leak is before the 4x4 part of the vacuum system.
You can also observe how the hubs operate and even narrow down to one side or the other. Remove the vacuum hose from the back of one hub. Hook the hand pump or just a plain vacuum guage to the hose. activate the 4x4. You will see the vacuum go up to 15 in. and then drop. Disengage 4x4. You should see a lower vacuum reading around 7 in, then drop. If not that means the opposite side wheel hub system has a leak.
Old Sep 3, 2007 | 10:42 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
And, it's really not binding - the u-joint at a steep angle spins the axle at a non-uniform speed - the axle is accelerating and decelerating rapidly, and the axle and spider gears flopping around is what's making the noise.
No biggee
Old Sep 4, 2007 | 08:09 AM
redford's Avatar
redford
I would take a serious look at your hubs. They are usually the source of ESOF problems.
lud04X
Mar 12, 2020 12:09 PM
Eric Mahoney
2009 - 2014 F150
Dec 28, 2017 06:37 PM
HpCowboy13
1978 - 1996 Big Bronco
Dec 15, 2015 01:54 PM
abe
17
Nov 8, 2011 12:12 PM
90pioneer
Jun 19, 2011 10:12 AM
