4180 Holley
Old Aug 17, 2007 | 02:05 PM
78ltd's Avatar
78ltd
4180 Holley
Anyone know the list number for the 4180 used on the 1979
460's? Did they put the ford part number on the carb body,
or on a tag? I'll be looking for one at swap meets and I doubt
I'll find any that still have their tags left. Thanks.
Old Aug 17, 2007 | 03:45 PM
LxMan1's Avatar
LxMan1
The Ford part number will be stamped into the choke horn on the front right side. You will be looking for something like a D9TE- number. I thought 79's used a 4160 though.
Old Aug 17, 2007 | 04:50 PM
78ltd's Avatar
78ltd
From what I understand, the Holley 4180 first design usage was
on the 79 460. It was a modifyed 4160 with sealed idle mixture
tubes.
Old Aug 17, 2007 | 07:17 PM
LxMan1's Avatar
LxMan1
Not good for performance, the mixture screws are in the baseplate behind some plugs that must be drilled out. I believe there are actually 4 mixture screws. 2 for the rear as well.At least the one I had off of a 85 Mustang GT did.
Are you doing a restore? Why would you want a 4180 over a 4160?
Old Aug 17, 2007 | 10:22 PM
78ltd's Avatar
78ltd
Cheaper, and it's going on a 76 460 in a Grand Marquis to replace the 4350. If it's off a 460, it'll already be calibrated for that application. The 76 is stock, no modifications. On a $400 car, I'm not spending $300 for a new one. Oh' and I know I'll need the adapter.
Old Aug 17, 2007 | 10:33 PM
LxMan1's Avatar
LxMan1
Yeah, make sure you get long studs because the 4180 and 4350 have the same bolt pattern unlike a Q-Jet which uses the smaller pattern so the studs will have to go thru the egr plate, adapter plate and carb from the intake.
Old Aug 18, 2007 | 07:54 AM
78ltd's Avatar
78ltd
10/4. Thanks for the info guys.
Old Sep 15, 2007 | 12:15 PM
78ltd's Avatar
78ltd
Holley Carb
Well, at the Arlington TX swap meet yesterday, I bought
a Holley List No. 80457-2 carb complete with all the proper
linkage for $10. Looks like I'll use it instead of the 4180 I
was looking for. Cheap enough. The date code was 2158,
which I'm assuming is 1998. I don't think they had the
-2 model out in 1988. I could be wrong. All the linkage
moved properly and there was a solid and steady rush of
air from the accel. pump holes, so I think I did OK. What
do you 'all think?
Old Sep 15, 2007 | 05:43 PM
LxMan1's Avatar
LxMan1
I have one on a 460. It runs fine. I also had it on a 351W for awhile until I swapped carbs between the two trucks because I'm going to be keeping the 63 and wanted my 750 Edelbrock. For $10, as long as it isn't cracked and leaks, you got a great deal.
Old Nov 13, 2007 | 12:38 PM
mgraveman's Avatar
mgraveman
I have a 4180 I just bought from a carb shop for $75. I don't like it and would sell it fo what I paid. It came off a 460 and comes with the adapter for a spread bore manifold. It was freshly rebuilt and has about 10 minutes of run time on it from me.
ozark1
Sep 21, 2010 01:56 PM
sum_weirdo
Aug 7, 2007 11:13 AM
SuperDutyDave
Oct 16, 2004 07:51 AM
oldhalftons
Apr 4, 2004 08:46 PM
