4180 Jetting?
Old Aug 5, 2007 | 07:49 PM
sum_weirdo's Avatar
sum_weirdo
4180 Jetting?
I've got the front bowl off my 4180 to fix something else (took forever to pick off the felt gasket) and as long as I've got the bowl off I figure I'll take a look at the jetting. Only the jets aren't stamped with the typical Holley **H, they got some weird looking code. But anyway, in your opinion is the stock jetting in a 4180 adequate for a largely stock 78 460?
Old Aug 7, 2007 | 10:27 AM
kermmydog's Avatar
kermmydog
From my experience 4180 that came on 460s with calif emmisions run .061 primary jet. but remember a stock 4180 has a two stage power valve. which requires less jetting. The thing you need to worry about with a 4180 is they didn't come with power valve blow out protection. Any back fire at all will blow it. 2 stage power valves are $30. blow out protection device is about $12. So if one hasn't been installed that is one thing you should do. Holley didn't start using blow out protection until 1992. 4180s were not build that late. A 4180 is smog carb that Ford used on the 460s, 351W, & in the Mustang's with 302 4bbls in the mid 80s up to 1986. 1987 came EFI in the Stangs.
Old Aug 7, 2007 | 10:40 AM
sum_weirdo's Avatar
sum_weirdo
It requires less jetting? I thought the idea of the two-stage was that it distributed the fuel burst rather than opening all at once. I'd think it would take more jetting. Incidently I took out the two-stage valve yesterday because I wanted to see what it would do with single-stage. I put in a 7.5 I had lying around. The carb is still in pieces so I haven't test anything yet.
Old Aug 7, 2007 | 11:13 AM
sum_weirdo's Avatar
sum_weirdo
Okay now I get it. The two stage starts to open sooner so the initial effect is richer. So I may want to step up a bit. Although I'm at 3000 feet so the 61 jets may turn out to be just about right. I've got some 63s I could throw in it.
Tkc432
Mar 5, 2016 09:26 PM
Xwarrior86
May 27, 2015 10:19 AM
quakerj
Dec 23, 2014 07:42 PM
LKCKR
Jun 21, 2014 09:24 PM
bobj49f2
25
Apr 29, 2014 08:54 PM
