Motorcraft 4180...Dashpot..
Old Sep 14, 2010 | 08:19 AM
ozark1's Avatar
ozark1
Can anyone tell me the correct part number for this item ?. I need to start looking..thanks..JV
Old Sep 14, 2010 | 04:15 PM
Franklin2's Avatar
Franklin2
I plugged in "dashpot" in the search box at Autozone and a universal one from Holley came up. I don't know if it will fit or not, but you could take a look and see if it would. The 4180 is a Holley carb so there is a chance it might fit.
Old Sep 14, 2010 | 04:19 PM
ozark1's Avatar
ozark1
Thanks..I'll try it..j
Old Sep 14, 2010 | 06:36 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
It is a different thread size and if you re-tap your bracket it doesn't work well.
I STILL haven't been able to find the original part, or it's number.
Just a heads up.
Old Sep 14, 2010 | 06:46 PM
ozark1's Avatar
ozark1
Autozone lists the one for the 351 HO..as Unavailable..
Old Sep 14, 2010 | 06:56 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I can give you the Ford part number, see if it's available, list the sources that have some if it isn't, but...
The ONLY way to look up carburetor parts in Ford parts catalogs after 1979 is either by the carb ID tag number, or by using the vehicles specific Calibration Code.
Beginning in 1980, there were no longer any application charts for carb or emission parts. It was a PITA back then and it's a PITA today.
This is why I don't post too often in the 1980 and later forums, because I need either the ID number off the part, the carb tag number, or the fracatta Calibration Code.
And...there can be as many as THIRTY different Calibration Codes for just one specific year vehicle with the same engine, trans and etc. I kid you not.
So, if you don't have the carb ID number, I will attempt to look up the part without it, but there is no guanantee this will be possible. And...sold new in CA...or not...also makes a difference.
In this case, I need the truck's specific year, series, engine size, and...sold new in CA or not. I cannot go by Motorcraft 4180, there are too many variations.
Old Sep 15, 2010 | 09:38 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Sorry for the off topic ...
However, It's nice to see you about NumberDummy, How ya feeling ...
-Enjoy
fh : )_~
Old Sep 15, 2010 | 03:43 PM
ozark1's Avatar
ozark1
Bill..Ask..And ye shall receive...1984 F-150..2WD..NON-Calif. Auto..A/C..351 HO...DashPot/Fast Idle Switch....List ..50174...Date code..9510....TAG INFO.....E4TE....ARA....A4E18...Electric Choke...thanks..JV
Old Sep 16, 2010 | 07:21 PM
NumberDummy
E4TE-(9510)-ARA.
1980/89 Ford Light Truck Parts Catalog (on FoMoCo microfiche slides).
E4TE-ARA = Carburetor parts listed in Text, Section 95. Your carbs specific parts list # 95.5E / Text, Section 93 = Calibration Code parts list # 399
There is no 'dashpot/fast idle switch' or 'solenoid and dashpot' listed for your trucks application, what is listed is:
E3PZ9503A .. Throttle Modulator (Motorcraft CM4215) / Obsolete
GREEN SALES CO. in Cincinnati OH has ONE = 800-543-4959.
COLLECTORS AUTO SUPPLY in Oroville WA has TWO = 800-414-4462.
No Ford Dealer, no other obsolete parts vendor has any.
Before buying from one of the above, give the Motorcraft part number to NAPA or an indie autoparts store.
Dunno know about Auto-Zone, Kragens and etc., but Motorcraft part numbers can be crossed over to the brands the above sources sell.
Old Sep 17, 2010 | 07:21 AM
ozark1's Avatar
ozark1
Bill..I don't know how..(or why) you do it..but THANKS again..JV
Old Sep 17, 2010 | 05:58 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I wonder what condition the rubber diaphragm's are in, if these are NOS from 1987.
Old Sep 17, 2010 | 06:23 PM
ozark1's Avatar
ozark1
I'll start making some calls Monday..I'll post what I find out..j
Old Sep 21, 2010 | 01:56 PM
ozark1's Avatar
ozark1
Called Greens with the part # from Bill..and the carb. tag info.. Had ONE..$25.00..I'm having Pony Carbs. build a Motorcraft 4180 to go on my bone stock '84..351 HO..When they get done..it's like a completely different carb...Thanks again to Bill..This is the second time he has helped me...JV
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Oklahoma Chapter
Apr 11, 2003 10:33 PM
walterdanek
16
Feb 16, 2001 07:56 PM
