Sponsored by: Innova
Excursion CD Player
Old Aug 16, 2007 | 08:49 PM
snwbrdbus's Avatar
snwbrdbus
4wd Low
Excursion CD Player
My 2002 Excursion 6 CD player is presenting an error meesage on display and will not play CD's. Radio on ubit still works. I was wondering if anyone has had this problem and how do I get my CDs out of the unit. Any suggestions for a replacement. Thanks
Old Sep 4, 2007 | 08:26 PM
Rushmore X's Avatar
Rushmore X
Any thing happen with this? mine just locked up today.
Old Sep 4, 2007 | 09:28 PM
snwbrdbus's Avatar
snwbrdbus
4wd Low
Tried Many Techniques
I tried most of the techniques on this site to fix the problem with my CD player. I ended up taking it out of the dash and taking the unit apart to get the CDs out. I put it back together and it will load and play CDs but won't eject them without using a credit card. So I had to order a new one off of e bay.
Old Sep 5, 2007 | 04:52 AM
Rushmore X's Avatar
Rushmore X
tried another idea someone else posted... pulled fuses to the radio, and reinstalled them after 30 minutes. All seems to work again, and didn't lose my presets as I though that i would.
Old Sep 19, 2007 | 10:52 PM
supra88's Avatar
supra88
if you unplug power from the unit for 20 minutes it will rest the indash cd changer
also holding the scan and button 1 when it shows wait release and it will move the cd changer to the front called shp mode ,remove the fuses or negative terminal from the battery when the radio is power again it will move the cd changer arm to the back and start over
If this don't help the radio needs to be service
Old Sep 23, 2007 | 11:39 PM
belandd's Avatar
belandd
Smile CD Player
I had same problem in 2002 unit. Removed unit but still could not get CD out. Reinstalled unit and it started working fine.
No problems since.
I think disconnecting the power reboots the processor and starts it working again.
Old Sep 24, 2007 | 02:47 PM
MikeInFla's Avatar
MikeInFla
Mine is in a 2000 Ranger. Is a single disc player with cassette. Cassette and radio work fine but CD will not play or eject. Will try pulling the fuses and see what happens.
proudfrog
Nov 4, 2022 06:37 AM
jmstett
Sep 6, 2005 05:50 PM
Capita
20
Aug 28, 2005 09:58 PM
jackinsac
Nov 23, 2004 01:12 PM
roof it
2004 - 2008 F150
May 20, 2004 05:40 PM
