Frozen Distributor
Old Aug 15, 2007 | 07:17 PM
scoony's Avatar
scoony
Frozen Distributor
<o> </o>I have a 87 F150 with the 5.0. The timing is off by 5 degs but the distributor is frozen and can not be turned. I have sprayed PB buster but no luck. Is there a special tool or trick to get these unstuck?
I am thinking that there must be a tool since there seems to be a small section that a wrench could fit on, but it would have to be bent to get down in there.
Old Aug 15, 2007 | 07:31 PM
87f1504x42001's Avatar
87f1504x42001
my uncle has an 89 lincoln with the 5.0. and he had to buy a special tool from the parts store to loosen the retaining bolt up and adjust it
Old Aug 15, 2007 | 09:15 PM
scoony's Avatar
scoony
The retaining bolt is not an issue. It is the distributor itself that will not turn.
Old Aug 16, 2007 | 06:22 AM
92F150Flare's Avatar
92F150Flare
welcome to FTE
Not too long ago there was a post about this and dry ice was the solution. It worked for two different people . Cool the dist shaft with it. Give it a try.
Good Luck
Bob
Old Aug 16, 2007 | 07:29 AM
subford's Avatar
subford
Turn the crank back and forth and watch the play between the movement of the crank and the when the rotor starts to move in the distributor.
If the play is more than 2 Deg (should be zero) at the timing mark replace the timing chain.
Put it back together and check the timing, I bet it will be close to 10 Deg BTDC with the SPOUT out and you will not have to move the distributor.
I bet the play is about 5 Deg now and if you do not change the chain it is going to leave you on the side of the road.
Old Aug 16, 2007 | 08:10 PM
scoony's Avatar
scoony
OK I got it. went and got a chain wrench from NAPA and had a tight fit getting it in there, but it did the trick to get it loose. The timing is now set, but the engine still runs rough and does not have the power it should. It is drivable and once up to speed does fine.
Only 84k original miles on it so I am not sure it would be the timing chain.
I already put in a new ECT sensor and Idle Air control
Checked spark plug wires and did not notice a difference when pulling them one by one. Looks like the filter has been changed already as I don't think NAPA filters are original equip.
I Will change out the distributor cap and rotor and see if that makes a difference, the only other thing I can think of is mayby the fuel pressure regulator.
Old Aug 16, 2007 | 10:12 PM
netscaner's Avatar
netscaner
If your distributor was pretty well stuck, then it probably hasn't been moved in quite a while, meaning it was probably where it should have been.....................so messing with it may have contaminated the evidence you need to properly trace this down.
Quite obviously the problem wasn't that the distributor jumped, or that someone moved it.
Make the checks that subford suggested, he knows his ****.
And the checks won't cost anything.
Old Aug 17, 2007 | 11:15 AM
scoony's Avatar
scoony
Tried Subford's test and rotor and crank moved together.
I also ran the self test or think I did anyways and came up with "22" which points towards the MAP sensor. I checked the voltage between the return and signaland got 3 volts but my volt meter is not very good so that may not be accurate. Should have between 4 - 6 volts.
I still need to check for vacume leaks and was told that using carb cleaner and listening for the engine to rev up was a good way to check for leaks.
Any other ways to test the MAP sensor without a vacume pump?
Old Aug 17, 2007 | 11:43 AM
subford's Avatar
subford
When you said it was 5 DEG off did you have the "SPOUT" out?
Old Aug 17, 2007 | 11:50 AM
scoony's Avatar
scoony
Yes, I had the spout out. I have it set at 10 deg but now the engine runs worse. Loaps at idel and loss of power, so I am thinking a couple of things
1. Test pointed to MAP sensor but that could also be vacume leak I think
2. I may have damaged the distributor in some way, but I was carefull in working with it.
3. Fuel pressure reg, but not sure
4. Fuel pumps but again not sure.
Old Aug 17, 2007 | 12:07 PM
subford's Avatar
subford
Did you recheck the timing after you put the SPOUT back in to see if it moved?
If it did not move that could be why someone set the timing to 15 Deg.
Old Aug 17, 2007 | 12:45 PM
scoony's Avatar
scoony
Yes and it fluxuated around 5 deg from the 10 deg mark with the spout conected
Tsluv61
18
Nov 6, 2008 01:30 AM
mario56
Aug 15, 2004 09:36 AM
eric007
May 20, 2004 12:30 PM
david troupe
Oct 24, 2003 05:59 AM
Matt
Dec 17, 1999 02:27 PM
