1978 - 1996 Big Bronco
Will these injectors work?
Old Aug 15, 2007 | 03:23 PM
kameronth's Avatar
kameronth
I need some new injectors on my 88 Bronco 302H.O. I found these on ebay and they are 19lbs. He does not have my year of bronco listed but they sure look like they are the same as mine now. It is ebay.com. Here is the item # 270155231262
Old Aug 15, 2007 | 04:59 PM
Conanski's Avatar
Conanski
All the 5.0 Ford motors from this vintage use the same 19lb injectors. You don't have a 302HO either unless it was swapped in from a car. Regardless.. same injectors used on the HO motors as well.
Old Aug 15, 2007 | 05:15 PM
kameronth's Avatar
kameronth
Thats what I was thinking. I do have a H.O. motor I installed about 3 years ago or so from a Mustang. I have purchased all of the parts for a mass air conversion and I figured I would replace my injectors at the same time. Last time I had them out all the plastic was cracked and what not.
Blitzcraig
Jun 11, 2013 05:46 PM
RP27G8G
Jan 24, 2008 06:11 PM
Trevor1
Jul 10, 2006 10:41 PM
bf179
Nite, Nascar & Other Limited Edition Ford Trucks
Mar 25, 2004 01:42 PM
ecsmith0624
Nov 21, 2003 12:16 PM
