BTW if you leave tim I will commit i-net suicide!!
GOTCHA. Oh well all in good fun.
BTW Tim the oil bypass hose for your frantz filter by the oil filter housing probably should be 1/8" npt, mine was anyway. I can't remember what the one for the Radiator bearing was though.
But it is nice to know where it should be...the wires are only so long on the wiring harness that was taken off of the 97...........cant be too far from the original position designated by FORD...
It is in the standard location, but the Emergency brake bracket is huge and would require removal of most of the dash to get to the unit inside the truck. Can this be removed from the outside? More guidance please.
