Started a while ago and I posted in the Big Bronco forumn with little luck, no offense kemicalburns I just thought I might get more responses here.
1990 5.0 in a Bronco. Starts fine and idles and runs great for about 30 seconds to a minute. Then it starts to vibrate somewhat like it is only firing on 7 cylinders. This vibration continues throughout the rpm range as I drive. This occurs with and without the air conditioning on.
What I have done so far. New Autolite Copper Plugs, new Accel 8mm wires, new cap and rotor, timming at 10* btdc, new fuel filter.
No I havn't had much time lately to work on it. It still runs and drives so Last night I went to a dealership looking for a good used truck. When I got done driving interstate for about 30 mins it was running great again. Go figure, it runs fine after I threaten to replace it with a new daily driver.
Try cleaning the throttle body and any EGR stuff next to it. My bro's 90 GT was doing the same thing and he cleaned it up pretty good and it helped a lot.
Ok, I know I am a bad listener because I haven't had any timie since I first posted this to try any of the suggestions above, BUT I have anther question first.
Since I first posted I have noticed that the truck runs fine as long as I don't get the motor above 2,000 RPM's. However, once it is above 2000 RPM's the vibration starts and wont stop until I turn the truck off for a while.
At night take a spray bottle with water in it, spray down the plug wires from dist. to plugs, start the truck turn off all lights, look around for sparks jumping wire to wire and from wire to metal on the motor or frame or to low voltage wires(bad bad bad if it's sparking to sensor wires!!!). If you see quite a few sparks you need to either reroute the wires, install more seperators or put split loom over the wires. Definately triple dose it with dedicated gas line dryer get both types isopropyl and methanol dump it in 1/2, 1/4 tank whatever dump in 2 bottles of each run it until almost empty, refill with fresh gas and 2 bottles of iso-heet. A bottle every oil change won't break the bank and could prevent future problems!! My vote is for cross firing plug wires or it could be jumping to a sensor wire intermittantly and screwing with it!!
