General Automotive Discussion
squeak in 413
Old Aug 14, 2007 | 11:47 PM
scrapyardking's Avatar
scrapyardking
squeak in 413
I have a 413 chrysler motor in my 79 ford tow truck and latly i have noticed a high pitched squeaking niose coming from the motor. Id like to get some of your ideas on what it is because it realy sounds bad. I have allready taken off the belts to see if it was coming from the accessories but its not . any clues on what it could be would be greatly apriciated. Thanks
Old Aug 15, 2007 | 11:21 AM
loudfords's Avatar
loudfords
It's your truck complaining about being Chrysler powered.
It could be a small vacuum leak under the carb somewhere. Is it a squeak or a whistle?
Old Aug 15, 2007 | 03:39 PM
scrapyardking
It definatly sounds like metal on metal somewhere. and it has brand new oil in it
Old Aug 15, 2007 | 09:41 PM
Ford_Six's Avatar
Ford_Six
It sounds like a rod bearing might be shot- they usually squeak when they get really bad.
Is the oil shiny?
Also could be a separated damper.
Old Aug 15, 2007 | 10:30 PM
scrapyardking
Thats what i was afraid of the motor has over 200,000 miles on it. But i gess ill just run it till see goes.
Old Aug 15, 2007 | 11:29 PM
85e150's Avatar
85e150
What is the frequency of the squeak? Crank speed or half? That would indicate mains vs. valve trouble. Can you use a stethoscope and isolate it?
Shame to risk loosing the block if you can tear it down before it blows.
Plus, they never blow just outside the shop on a little hill so you can roll it over to the shop door, now do they???
Old Aug 16, 2007 | 09:01 AM
Kwikkordead's Avatar
Kwikkordead
My guess is a vacuum leak at an intake runner.
But I don't know what a 413 look like so it's just a guess.
TexasEX2K
Jul 5, 2012 10:46 PM
davewave649
Sep 27, 2011 04:02 PM
06f150CO
Modular V8 (4.6L, 5.4L)
Feb 21, 2011 06:10 PM
jjovel413
1978 - 1996 Big Bronco
Feb 23, 2007 03:05 PM
schweg2
Dec 28, 2001 01:01 PM
