Modular V10 (6.8l)
Flutter fix
Old Apr 1, 2004 | 06:42 PM
  #31
derbyking's Avatar
derbyking
well my problem wasnt either of the two.this truck had a very metalic tingging noise that started about 1800 rpm and if you reved it it would increase and decrease.it was not noticable at idle.it sounded like a loose washer on a bolt rotating and ratteling,or a peice of pipe that was slid over a smaller peice and left loose to turn.
the fix.....ford has a ruducer in the egr tube,between the two pfe sensor tubes welded in the side.its suposed to be press fit,it came loose,new tube $58.00
i used a long thin screwdriver and drove the reducer back in tight,going in from the manifold side of the egr tube,then ran a peice of fuel line down the tube until it hit the reducer,marked the line,held it to the outside of the egr tube and drilled a small hole in the side of just the tube,stoping at the reducer,small spot weld and itll never happen again.
runner
Aug 19, 2015 11:41 AM
kawcrasher
18
Oct 19, 2011 08:59 PM
Enomra
Jul 29, 2008 10:22 PM
Brianut
Apr 28, 2008 07:59 PM
markshyd
Aug 31, 2001 07:17 PM
