Modular V10 (6.8l)
To anyone looking at headers
Old Apr 14, 2008 | 07:33 PM
  #46
Johnny Langton's Avatar
Johnny Langton
Originally Posted by krewat
Here's some pics of my cheapo eBay ones:
http://fords.kilonet.org/krewat/v10-headers/index.html
A few people had asked about headers in the past few weeks, so I figured I'd post up what I had done.
How thick are the tubes on those? If they're thinner than 16 gauge watch the shortest tubes for cracking around the collector right next to the welds.
JL
Old Apr 14, 2008 | 09:56 PM
  #47
krewat's Avatar
krewat
FTE Leadership Emeritus
JL
They're at least 16 gauge...
Old Apr 14, 2008 | 10:05 PM
  #48
jpeters1's Avatar
jpeters1
I think that it is gonna be a pain in the a$$ to install my ebay headers in my 99 F350 2wd. The front coils block just about everything for access from the wheel well. Anyone done headers on a 2wd?
Old Apr 15, 2008 | 09:33 AM
  #49
krewat's Avatar
krewat
On my 4x4, I removed the shock towers to get better access. Other than that, wow, that would be a hard job without removing that spring tower.
Any chance of removing the coil and tower?
Old Apr 15, 2008 | 07:04 PM
  #50
slappysdump's Avatar
slappysdump
You can get just the headers/y-pipe setup seperatly from Banks and several online stores. I would do a search. I looked at Banks while shopping for headers and found a few places that sell the just the headers and y.
Thanks I will look around some more, by the way do the headers and y pipe bolt up to the oem pipe or does it have to be modified?
Old Apr 15, 2008 | 07:14 PM
  #51
dkf's Avatar
dkf
The Banks is supposed to be one of the best fitting header/ ypipe setups on the market. The Y-pipe connects at the triangular shaped flange in front of the cat converter. There is some wiggle room in the exhaust system.
Old Apr 15, 2008 | 11:04 PM
  #52
Antelope V-10's Avatar
Antelope V-10
Unless Banks has changed, you used to have to cut the flange off if the triangle connector was in front of the crossmember. On the earlier models that had the connector behind the crossmember, it would bolt right up.
Old Apr 16, 2008 | 01:40 PM
  #53
dkf's Avatar
dkf
You may be right, As you know I don't have the Banks set-up I have the Thorleys. I was just going by the install pics I've seen on the net and Banks pictures. My Thorleys bolted right up to the triangular flange.
Did you get your Throley's on yet Antelope?
Old Apr 16, 2008 | 01:43 PM
  #54
dkf's Avatar
dkf
JL
The problem I see with the Ebay headers is the Welds themselves. They are TIG welded. The reason other header manufactuers MIG weld headers is not just because MIG is cheaper but that it has a higher metal deposite rate which produces a larger, thicker and stronger bead than the tiny TIG weld beads on the Ebay headers. If you MIG weld the ebay headers they won't crack.
Old Apr 16, 2008 | 05:23 PM
  #55
Antelope V-10
[ "Did you get your Throley's on yet Antelope?[/QUOTE]
No not yet, they are still in the box on the garage floor.
Old Apr 16, 2008 | 05:27 PM
  #56
Johnny Langton
I'll argue with you on this.
Tbirds have problems with JBA headers doing the same thing,and they're 16ga tubing. We've tried MIG welding them to repair,and it cracks right near the welds again afterward. Tbirds don't see anywhere near the heat in the manifolds/headers as a truck does(esp the V10 that stays in stoich air/fuel all the time)-I just don't see "shorty" headers lasting for long term on a truck.
The fuel strategy on the V10 of stoich air fuel all the time is also a suspicion of mine as to why so many guys have problems with the studs breaking off. Excessive heat and expansion eventually deteriorates the studs to the point that they fail.
JL
Old Apr 16, 2008 | 05:37 PM
  #57
dkf's Avatar
dkf
JL
It could be a weak point on the shorties then. I don't know where on the shortie Ebay headers that they broke. TeamMudd said he has seen several ebay V10 headers crack, I don't remember if he said where though. Stainless headers are more sucetible to cracking because of the alloys used within. 16 Ga. is not very for headers IMO, thats one reason why I went with the Thorleys for my truck, 14Ga tubing. You could try welding the cracked headers with a Nickel rod. The Nickel will stay soft afterwelding and be less suceptable to cracking. Nickel is used to repair cast iron also.
Old Apr 16, 2008 | 06:13 PM
  #58
Johnny Langton
14Ga tubing.
I agree,IMO-all truck headers should be at least 14 ga tubing. The problem on the shorties is the distance and size of the tube and expansion when hot with very little area to allow flex when expanding.
JL
Old Apr 16, 2008 | 08:47 PM
  #59
shadows4's Avatar
shadows4
All this talk of headers is very interesting but I have a question about the stock manifolds. If I were to just keep the stock manifolds what would be the best way to go, replace just the broken studs (so for I only have 1 broken) or replace studs with bolts? Thanks, John
Old Apr 16, 2008 | 10:53 PM
  #60
biz4two's Avatar
biz4two
Arrow
If you keep your OEM stock exhaust manifolds, then you will first need to determine if they are warped. If they are...then you will need a machine shop to correct that.
IMO...just go with replacing all the studs...with studs.
biz
