the borla headers went right in with no major moves. so did the y pipe and the split side exhaust. lucky for me the 3 broken studs were all accessible.
I don't know if you'll be able to tell any difference between long tubes and shorties.
The Thorley's are probably the closest to long tubes that will fit.
If I were a betting man, then I would say the long tubes would increase the low end torque feel. Something that would certainly be noticed.
These shorties usually keep the low end the same or hurt it a bit...but will be felt on the high RPM's. So...the long tubes would just be the opposite...IMO.
As in not having to raise the engine? Are broken studs from taking them out or are they breaking by themselves? Mark
The graph Thorley sent me shows a H.P. gain of 26.4 and a Torque gain of 40ft.lbs.
I looked up JBA, they show 38H.P. and Torque 73 ft.lbs over stock.
Banks shows 49.2 H.P. and Torque 58.7 ft.lbs over stock. This of course is with their full Power Pack minus the Ottomind.
I would like to see a dyno run of shorties {JBA, Gibson} with a Stan's or E-bay Y-Pipe mod.
Others have mentioned the Ford Racing headers. If you go that route, I do believe they are NOT smog legal if you have that in your state.
You have to remember that those numbers come from the biggest gain at a said rpm over stock.
The numbers are not HP and Torque gains at PEAK HP and TQ as they would like you to believe.
You may (but I doubt it) get 73ft.lbs more torque over stock with the JBA headers, however that may be at 5400rpm, when the peak torque is around 3200rpm. HP numbers are similar too.
I'm not trying to attack you or your post Antelope. Just trying to put the manufacturers claims into perspective.
No biggy dkf. All 3 mfg. I mentioned have dyno graphs available to see at their respective websites. I tend to believe them just for hoots I guess. The JBA Dodge v-10 headers show an increase of 15 H.P. and 16.08 ft.lbs of Torque over stock. Not much of an increase. I guess my point is they could have made up some real big numbers to sell headers if they wanted to. Personally I wouldn't go to all the trouble for those low numbers.
biz
See, this seems bass ackwards to me, no offense Bobby. On race cars that I've been a part of, we used long-tubes for high rpm/blower/nitrous combo's. When we were still naturally aspirated, only slightly modified, we ran shorties to keep the torque numbers up. Long tubes on a lightly modded V8 made it a dog off the line. But I don't know, maybe this V10 is just a different animal.
Again, no offense Bobby. I'm not trying to discount what your saying!!
See, this seems bass ackwards to me, no offense. On race cars that I've been a part of, we used long-tubes for high rpm/blower/nitrous combo's. When we were still naturally aspirated, only slightly modified, we ran shorties to keep the torque numbers up. Long tubes on a lightly modded V8 made it a dog off the line. But I don't know, maybe this V10 is just a different animal.
Again, no offense. I'm not trying to discount what your saying!!
None taken. It might be a V10 thing, because why would they make a long tube header for the motorhomes where torque rules...over hp?
