stuck oil filter
Old Aug 12, 2007 | 03:47 PM
Big Swole's Avatar
Big Swole
stuck oil filter
ok I have had this problem before, I used the proper tools first (oil filter wrench, both strap and metal). Then went to the screw driver(shredded it) and finally cut it off with a dremel. I know the usual cause is someone failed to lube the gasket before putting it on( wasn't me).
My wife let someone do her oil change the last time. Now I am changing the oil and same darn problem, stuck like chuck. I have done the same things as above and am in the process of cutting it off carefully. !@#*#!!
Does anyone else have another way of doing this that has not made it to my vine yet? If you do please enlighten me for I am about block up the truck and use it as a dumpster!!!!!!!!(in the front yard of course)
Old Aug 12, 2007 | 03:51 PM
Kwikkordead's Avatar
Kwikkordead
I use a VERY heavy duty steel oil filter wrench that is 4" wide. It will grip the tightest filter without collapsing it and spin it off using a 1/2" drive 2 1/2 foot long breaker bar.
It's made by K-D and I will try and find the part number after this post.
Old Aug 12, 2007 | 03:52 PM
Big Swole's Avatar
Big Swole
I tell you, that you are a saint. I appreciate it.
Old Aug 12, 2007 | 03:54 PM
Kwikkordead
Here you go: $22.95 at www.napaonline.com
http://www.napaonline.com/MasterPage...+Filter+Wrench
If the link doesn't work it's part number: BK 772320
The thing is a beast, it will get your filter off, guarenteed.
Old Aug 12, 2007 | 03:55 PM
Big Swole's Avatar
Big Swole
I thank you again. I'm off to order it right now!, Thanks
Old Aug 12, 2007 | 03:58 PM
Kwikkordead
You'll like it.
fordzilla01
49
Apr 30, 2011 04:26 PM
Flywest
28
Apr 23, 2008 09:17 PM
JimZockoll
2004 - 2008 F150
48
May 2, 2007 11:45 PM
wildcard30
Oil & Lubrication
24
May 10, 2004 11:30 PM
GunnerRob
Oct 25, 2003 08:36 AM
