600cfm on 460 stalling problems
Old Aug 12, 2007 | 03:24 PM
79f100six's Avatar
79f100six
i just had a question about my friends 460. It was rebuilt by his dad about 10 years ago and sat until my firend put it into his truck. He has a edelbrock 600cfm on it and the problem is if you put the throttle more than half way down the truck will studder and stall. My friend thinks that it is the carb because it is too small for what he thinks his 460 is the biggest motor in the world and will eat the carb, but i told him no because you guys run these carbs and have no problems. what do you guys think.
Old Aug 12, 2007 | 04:10 PM
69-highboy's Avatar
69-highboy
I believe he has gunked up secondaries and needs a carb kit. The sputtering/studdering/stalling is caused by a lean fuel mixture. It probably wouldn't hurt to squirt some gum out down onto the metering rods and check for free movement.
Old Aug 12, 2007 | 04:57 PM
79f100six's Avatar
79f100six
by saying carb kit, you mean a rebuild kit or a kit with different jets and metering kits.
Old Aug 12, 2007 | 05:01 PM
69-highboy's Avatar
69-highboy
I mean a rebuild kit. It is possible that carb is too lean for your application, however, most of them were set up to run on stock rigs from the get-go and if someone else hasn't modified it, it should work fine after the rebuild kit.
Old Aug 12, 2007 | 06:11 PM
79f100six's Avatar
79f100six
well i just talked to my friend. and he told me that he had to take the intake off because of an oil leak and i guess the timing was way off and the carb spacer was the wrong kind and didnt allow the secondaries to open all the way. But he told me after that the truck was a hole new truck and could burn the tires off on cement (before it wouldnt even turn the tires over in dirt).
KidWithTheLoudFord
Mar 5, 2016 11:10 AM
Tim64
Oct 23, 2015 07:56 AM
dieselburner6.0
Apr 25, 2007 12:08 PM
78bigunns
17
Jun 27, 2006 07:53 AM
jamies460
30
Oct 3, 2005 12:21 AM
