Glow Plug Relay Mod
Old Aug 10, 2007 | 01:04 PM
pctjk's Avatar
pctjk
Question Glow Plug Relay Mod
I am attemping to install the Glow Plug Relay Modification as per Guzzles mod page...http://guzzle.rbmicro.com/s_gpr.html: I did not see any where the year of PSD he worked on in the article. I ordered the Glow Plug Relay, received it and went to install it last night. Well, I ran into a problem. My PSD is a 99 SD. On the side of the OEM GPR there is a brass strap that connects to one post of the relay down to two other terminals. I assume this acts like a shunt and is part of the monitoring system. When I removed the OEM GPR, This strap assembly would not fit on the new GPR. Has anyone done this mod and had this same problem and what did you do to resolve it?
I contacted Mouser and they will accept the GPR back, which is good.
Does anyone have a part #, source to upgrade the OEM GPR? Do I then settle for OEM, Napa, Schucks, Autozone Etc?
Thanks in advance.
Jeff
Old Aug 10, 2007 | 01:12 PM
wlihntr's Avatar
wlihntr
if you have a california model truck or excursion which uses a glow plug controller and not a relay, that mod may not work
Old Aug 10, 2007 | 01:14 PM
pctjk's Avatar
pctjk
What's the difference? My truck is from Nevada.
Old Aug 10, 2007 | 01:27 PM
wlihntr's Avatar
wlihntr
all califorina trucks and all excursions use a glow plug controller (for emissions i think) and it is different than the plain relay. did you buy your truck new in nevada? i think the GP controller has that shunt on it, thats what made me think of that
Old Aug 10, 2007 | 01:30 PM
pctjk's Avatar
pctjk
I purchased my truck Used in Nevada. What happens if I do not use this shunt? and eliminate it?
Old Aug 10, 2007 | 01:35 PM
wlihntr's Avatar
wlihntr
so it could have easily been sold new in california. i dont know what would happen if you didnt use it. i know the system is different but dont know much about it. at the least it would probably through some codes
Old Aug 10, 2007 | 01:42 PM
pctjk's Avatar
pctjk
I think you're right. The computer did throw a 1395 code which is a glow plug monitor fault. I plan on changing out the GPR and glow plugs before winter sets in. I'd like to have more info on this shunt if I can find it. If anyones else knows...pass it on.
Thanks for your replies
Old Aug 10, 2007 | 06:18 PM
Orezona's Avatar
Orezona
All Guzzle's write-ups are on his truck. His home page is titled "guzzle's 2002 Ford Powerstroke Diesel Web Pages"
http://guzzle.rbmicro.com/index.html
Fordman96
13
Dec 1, 2014 08:29 PM
Cuda_jim
67
Dec 8, 2013 10:26 AM
540milotalon
Mar 17, 2011 12:53 PM
phillips91
Feb 16, 2009 12:12 PM
