power loss while towing
Old Sep 5, 2007 | 09:43 PM
  #31
Rod Jr.'s Avatar
Rod Jr.
A friend of mine had a similar problem as yours, it turned out to be a bad fuel pump not creating enough pressure, they also replaced his turbo.
Old Sep 5, 2007 | 09:53 PM
  #32
mlb4966's Avatar
mlb4966
Originally Posted by 01powerstroke01
speaking of turbo boots what should the clamps on the boots be torqued to?
As tight as possible... No I really do not know the torq specs but after blowing mine off a few times I have them pretty "cranked down".
Boy it sounds as if Ford really want to put the blame on his shoulders. Shame on them.
Old Sep 6, 2007 | 03:03 AM
  #33
Beerstalker's Avatar
Beerstalker
The clamps on the boots are tightened to 9 ft-lbs I believe.
Old Sep 7, 2007 | 02:19 PM
  #34
mlb4966's Avatar
mlb4966
Wow thats it, only 9 ft-lbs. Boy I bet I am past that. I had to replace my upper turbo hose due to a 2" crack in it. Not sure how that got there. The factory one had the clams stapled to it but the new one did not. I did noticed that each time I tightned the clamp they seemed to ride up over the "bumb" on the metal pipe. Also wish ford would of provided some sort of a bracket to secure the pipe to. It just flops around from what I noticed.
Old Sep 7, 2007 | 02:38 PM
  #35
ForemanES's Avatar
ForemanES
Our 04 6.0 had this exact problem where towing on flats it was perfectly fine but once you came up to any large grade it would loss power and it would only go like 30mph up the hill. I refinished the turbo and installed the new vgt actuator and it made no difference. We them thought it was the auto tranny and then decided to take it to the dealer. They had it for 2 weeks and finally were able to replicate our problem with their laptop plugged into it pulling a flatbed with a new pickup on it. After our diesel tech researched it and asked ford they came up with the replacement of the engine oil cooler and the egr cooler. The coolant temps stayed right at 180 while the engine oil temp shot up to 280-290. This caused the engine to defuel itself. Well close to $3000 later and the two coolers replaced it is pulling good. Oh the truck has 120,000 and was out of warranty. Also our tech said to stop unplugging the egr because it will affect the way the motor runs. Hope this helps
90pioneer
18
Jul 28, 2014 08:59 PM
RRranch
21
Mar 30, 2011 09:07 PM
olfordsnstone
Mar 17, 2011 10:32 PM
2001400ex
Sep 7, 2010 08:35 AM
'02STROKER
6.4L Power Stroke Diesel
Jun 24, 2008 05:10 PM
