6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Low Boost
Old Jun 21, 2008 | 08:05 PM
'02STROKER's Avatar
'02STROKER
Low Boost
I was pulling my trailer yesterday (15,000#), up a long grade. The first half of the grade I was maintaining 60-65 mph at 3/4 throttle, it was 90 degrees outside, and the fans were running pretty hard, boost was about 35-38 lbs. The road then flattens out for about 2 miles, & then another long climb, on the second climb the truck would only boost 20-25 lbs. @ 3500 Rpm. I backed out of the throttle & got back into it still same boost numbers. All guages read normal no warning lights on. Do these trucks defuel if egt's get too high? All my boots are tight & truck seems to be running fine. Any info is appreciated.
Old Jun 21, 2008 | 09:00 PM
SouthTexasDiesel's Avatar
SouthTexasDiesel
Possible regen cycle. Boost pressures tend to fluctuate when the truck is in regen.
Old Jun 22, 2008 | 12:22 AM
dt75flh's Avatar
dt75flh
my boost will drop to around 21-28 when regen under load and going up hill at freeway speeds
Old Jun 22, 2008 | 06:00 PM
'02STROKER's Avatar
'02STROKER
thanks guys, I will watch it next time I tow.
Old Jun 24, 2008 | 05:10 PM
SANDDEMON08's Avatar
SANDDEMON08
Yep sounds like an active regen, and yes the PCM will defuel when the exhaust temps go to 1400 degrees.
Tacswa3
6.7L Power Stroke Diesel
25
Nov 21, 2019 01:17 PM
RmMillertime
Feb 22, 2016 03:32 PM
Jeffrobeans
Nov 17, 2014 04:19 PM
johnny williams
Aug 26, 2013 06:15 AM
cavitation
34
Jun 15, 2010 12:28 AM
