Spearco Retrofit Intercooler Help!
Old Aug 8, 2007 | 01:46 PM
k2vailkid's Avatar
k2vailkid
Wondering if anyone else out there has put this unit on their rig, and if so, how and where do I get the intercooler boots that are long enough to bolt the piping up to the Y-pipe? I called Spearco and haven't heard back, and I can't get through to the gents at Black Widow Diesel. Thanks in advance for any help offered.....
Kevin
Old Aug 8, 2007 | 05:22 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
You need to get a hold of Brian because the Spearco Retofit CAC is supposed to come with a spacer pipe and the two intercooler boots. You also need to make sure your spacing is correct because I've heard the retro will rub the radiator.
Old Aug 8, 2007 | 08:39 PM
bbunting's Avatar
bbunting
This might help until morning
link
Old Aug 10, 2007 | 02:14 AM
k2vailkid's Avatar
k2vailkid
Thanks for the pics Brian!
Thanks for the tip Rampage, the fit is so tight. I can't get the crossmember to bolt up correctly if I push the IC much farther forward from the radiator. I hope the 2ish mm space is enough, I can't see how the crossmember would bolt up if I push the IC forward more.
Now that I know how the cold side boots fit, working on the hot side. I need a boot 7.5 inches long that I can kink about 15* or so. No part stores near here carry 3" I.D. silicone hose. And the stuff they can order that is 35psi rated comes 6"(too short) or 3ft for $210(no thanks).
I think if I had two more 3" silicone hump hoses and the stainless connector identical to the ones supplied for the cold side, I could rig up a boot to make the bend. Turbonetics is out of stock, and it looks like they expect more in early Sept. Anyone know where I could find these type of items?
F350BOSS
Nov 21, 2013 02:43 PM
tjustice
Jun 11, 2013 05:34 AM
Larry_the_handyman
18
Mar 1, 2011 10:10 AM
sawtooth
6.4L Power Stroke Diesel
Dec 13, 2010 08:59 PM
RAMPAGE_F350
13
Sep 8, 2006 04:22 PM
