Intercooler & Radiator
Old Jun 10, 2013 | 08:46 AM
tjustice's Avatar
tjustice
Getting ready to replace both. Intercooler either Spearco or Banks.....Radiator not sure on, any preferences????
Old Jun 10, 2013 | 10:15 AM
npccpartsman's Avatar
npccpartsman
Are you having a problem that requires replacing them?
Old Jun 10, 2013 | 10:31 AM
tjustice's Avatar
tjustice
EGTs are running higher than I would like. And ECTs are as well.
This with Atlas 40 on FICM, 65hp tune with SCT tuner. Had to do major repairs last year as most was posted Head, gaskets, studs, oil cooler, water pump and all that goes with it....During winter was bad at all, but since has got warm, temps have climbed daily run empty 200 plus ects, egts 1000 easy.. Haven't pulled hard yet,but that is coming up just trying to prevent walking.
Old Jun 10, 2013 | 11:12 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Might find a better deal somewhere else but this is supposed to be a nice radiator:
http://www.summitracing.com/parts/mi...250-super-duty
BeCool will sell you a similar one also. All aluminum.
Old Jun 10, 2013 | 12:10 PM
69cj's Avatar
69cj
The pic shows tranny cooler connections but the specs say no tranny cooler. Do your homework before purchasing.
Old Jun 10, 2013 | 01:37 PM
tjustice's Avatar
tjustice
That's why I am here, starting the homework process....
Old Jun 10, 2013 | 04:54 PM
npccpartsman
I might be a "tad" bit concerned about the 200* ECT's running empty but 1000* EGT's tuned is nothing. Consider that you're running a tuned FICM and PCM and you're getting quite a bit more fuel. Those alone will raise your EGT's quite a bit, but nothing a bigger intercooler is going to fix. I'd concentrate on what's making your coolant temps run that high (though they aren't that high). Have you changed the thermostat and/or checked fan operation?
Old Jun 10, 2013 | 05:06 PM
69cj's Avatar
69cj
Hey Tim, I run 195 to 204 ect empty or loaded depending on ambients. I think I got one of the good t-stats out of the factory. It's still the original and has always run there.
Old Jun 10, 2013 | 05:31 PM
tjustice's Avatar
tjustice
Thermostat is new, well replaced it and the water pump when I had it torn down. Not had it hot enough to get the fan to kick in.
Old Jun 11, 2013 | 05:34 AM
npccpartsman
That's pretty much what mine runs also Mike--actually 188-207 is more my spread. I try to stay out of the temp threads because my bulletproof doesn't act like a typical truck. I know my truck cools better running the A/C because fan operation happens more often.
Big-Foot
6.7L Power Stroke Diesel
20
Jul 25, 2014 10:51 AM
Special Ed
Sep 26, 2011 10:52 AM
AmeriKen
Jul 28, 2005 04:55 PM
JTdesert
13
Aug 9, 2004 12:49 PM
cigarxtc
May 10, 2004 09:25 AM
