Tire clearance question
Old 08-06-2007, 08:47 PM
gearhead351's Avatar
gearhead351
gearhead351 is offline
I have an 84 Ford F250 4x4. Currently it runs with 31x10.50 tires on it. Can 34.5x13.50 tires fit under it with a bit of rub? If not will a 3 in lift make them fit? thanks, Matt
Old 08-06-2007, 09:22 PM
Pkupman82's Avatar
Pkupman82
Pkupman82 is offline
Nice truck Matt! You should be able to fit 34s under your rig without lifting, you will have some rubbing... 33s are about the maximium for a stock 3/4 ton 4x4 Ford. I guy I was in the military with had a 95 F250 4x4 with a 3" suspension lift and 34x10.50 Interco Truxus Radials on 16x8" aluminum rims. You might concider going to a 4" suspension lift, 4" kits seem to be more plentiful. If you are thinking of going to a 3" body lift, that would probably work okay too... might be a bit tight with 13.50 wide tire, you may need to do some fender trimming.
Old 08-06-2007, 10:58 PM
gearhead351
Thanks! I proly figured a lift would be necesary but for the mean time until the I order the lift, I wanted to know if i could drive it until then! Where is the cheapest place for lifts?
Old 08-07-2007, 01:35 AM
Pkupman82's Avatar
Pkupman82
Well how much you want to spend determines the quality of the lift kit. Rough Country builds a decent lift. But if you plan on wheeling your truck hard you would be better off spending a little more $ and going with Superlift or Skyjacker. rockymountainsusp.com would be a good place to start shopping. Also check out Bronco Graveyard.
Old 08-07-2007, 09:28 AM
Sycostang67's Avatar
Sycostang67
Sycostang67 is offline
The width of your wheels and the offset with play a major part in the amount of contact you get. Those tires on the stock wheels would produce the least amount of contact.
Old 08-07-2007, 10:04 AM
clunker86's Avatar
clunker86
clunker86 is offline
i got a 86 f250 4x4 400 c6 and i am running 35 12.5 16 on factory rims with no major problems other then i cant turn the wheel all the way in a u turn. other then the rubbin on the leafs from turning the wheel all the way its fine.
clunker86's Avatar
clunker86
i got pix just dont know how to post them on here. a little help on how to post pix and i will post them. thanks
Old 08-07-2007, 02:52 PM
Sycostang67
There ya go. To post a pic from your gallery, right click on it, go to properties and copy the address. Then paste it on the page and add the image tags to it like so [IMG]photoaddress[/IMG]
74redone
1999 to 2016 Super Duty
08-30-2011 01:55 AM
matt12
20
09-14-2010 09:01 AM
fordtruckman
2004 - 2008 F150
13
10-18-2006 10:12 PM
MattC
05-06-2003 04:57 PM
92Custom
21
07-14-2002 02:57 PM
Quick Reply: Tire clearance question
