Sponsored by: Auxito
Suspension Issue?
Old Aug 6, 2007 | 04:13 AM
alkalineone1's Avatar
alkalineone1
Suspension Issue?
i think i am having a suspension issue. when i drive on the highway at high speeds i am getting an abnormal amount of consistent "bouncing". it typically happens when the highway is "worn". i understand that the concrete slabs on the highway are warped, creating this type of consistent bounce, but i think mine is a little exagerated. it does not happen on smooth highways. i recently put new tires on and balance is perfect. my last thought is maybe i need to replace my shock absorbers... any ideas. thanks!
2003
f-150 flareside
4.2 L
Old Aug 6, 2007 | 04:30 AM
LxMan1's Avatar
LxMan1
Welcome to the forum.
I would suspect the shocks are worn. How many miles are on the truck?
Old Aug 6, 2007 | 09:29 AM
alkalineone1
thanks for the reply! there are only about 50k miles on it. however, i do put a few offroad miles on it when entering and leaving OHV areas with my dirt toys. a lot of the time these dirt roads can get pretty harry when going too fast.
Old Aug 7, 2007 | 12:07 AM
LxMan1's Avatar
LxMan1
Is there any sign of oil on the shocks?
Old Aug 7, 2007 | 03:57 PM
new2diesel2's Avatar
new2diesel2
I have a major bouncing problem over 75 MPH and I have brand new tires. I was hoping it was my old tires being out of balance but no such luck. 168K on it and I assume the original shocks, any chance it's the ball joints? My g/f said she could see the tires bouncing when she is riding next to me.
Old Aug 7, 2007 | 04:50 PM
alkalineone1
ok, i inspected the shocks and i dont have any oil leaking. im going to assume i need a new set all around... and suggestions
Old Aug 22, 2007 | 10:47 PM
crmarshall's Avatar
crmarshall
New2, it sounds like you might want to get your tires balanced again. It isn't uncommon for a tire weight to fly off if the 16 year old kid at the tire store installed the wrong shaped weight. If your tires are visibly bouncing down the road it is definetly a balance issue. As the heavy side of the tire rotates it pulls the axle assembly up and down.
Old Aug 23, 2007 | 07:29 PM
alkalineone1
thanks for the replies. the reason i dont think its a tire balance issue it because the i am not getting and bouncing on smooth highway.
Old Aug 24, 2007 | 10:18 AM
bla1879's Avatar
bla1879
new2 that, to me sounds more like a shock issue than a balance issue, not having them balanced will roughen the ride, but if it is truely a major bouncing problem and you have 168k miles on the original shocks then its the shocks most likely, when you go over a speed bump (one of those big long ones not the little ones) or down a drive way or something like that, how many times does the car bounce after the speed bump? it should bounce no more than three times max, if you have more bouncing than that your shocks are prolly worn out needing replacement
Old Aug 24, 2007 | 11:57 AM
new2diesel2
Thanks for the responses everyone! I will check the shocks soon.
BigDaddyTom
Apr 19, 2012 02:26 PM
cornking
Jan 26, 2011 07:31 PM
caere
Aug 29, 2010 07:18 PM
cmullins
Mar 22, 2009 10:05 AM
97 HD
2004 - 2008 F150
Jan 19, 2008 07:01 PM
