Sponsored by: Auxito
On Shaky Ground
Old Aug 5, 2007 | 08:27 PM
just-n-time's Avatar
just-n-time
Cool On Shaky Ground
Ok folks,I got into a 2001 ford today that has a slight shake,I pulled the plugs and replaced all, gap .052, then the owner handed me 2 ox sensors so they are new,checked the wires they are from 7.6 to 5.54 ohms, I even took the egr valve off to clean it but it was in very good condition, my question, is it possible that the coil pack is going? I suppose I will due a compression test just to be sure, but the eng. is just so clean I might think that way if the thing was a beater but it is not. the only code came out #3 miss fire!
Old Aug 5, 2007 | 08:38 PM
galaxie641's Avatar
galaxie641
I would guess the #3 COP is bad if it is misfiring. Move it to another cylinder and see if the misfire follows.
Old Aug 6, 2007 | 04:51 AM
LxMan1's Avatar
LxMan1
It's either the coil, boot or possibly the injector.
Old Aug 6, 2007 | 05:58 PM
just-n-time
cop? not up on this term,please forgive my ignorance.JNT
Old Aug 6, 2007 | 06:00 PM
just-n-time
coil boot,this is a v6 it dose not have the individual coil and boot as the 302.
Old Aug 7, 2007 | 05:46 AM
Keeler's Avatar
Keeler
I would check out the injectors. The coil packs on those motors are basically bullet proof and when they decide to go, its not just one, its usually atleast 2 of the cylinders that go
Old Aug 7, 2007 | 11:51 AM
just-n-time
yes I will try some cleaning for the injectos and see if #3 has some trash in it. JNT
Old Aug 11, 2007 | 08:03 PM
just-n-time
Ok just to up date it turned out to be the coil. V6 mounted on left valve cover. thanks for the help. JNT
Old Aug 11, 2007 | 08:35 PM
LxMan1's Avatar
LxMan1
Originally Posted by just-n-time
coil boot,this is a v6 it dose not have the individual coil and boot as the 281 or 330.
Ah yes, this kind of info is most helpful when trying to diagnose a problem
Old Aug 11, 2007 | 11:09 PM
MikeFlorida's Avatar
MikeFlorida
My coil pack just went bad and it happened very quickly while going down the road. The code said #2 cylinder not firing. The truck ran, but it shook very badly like you described. Hope this helps.
Mike
59203shop
6.4L Power Stroke Diesel
16
Oct 3, 2020 03:09 PM
Bite N Hold
6.7L Power Stroke Diesel
Sep 21, 2015 03:45 PM
Daleksandrovich
Oct 29, 2014 10:12 PM
Iaff113
Sep 11, 2014 01:58 AM
HkyswiM
Dec 5, 2013 10:02 AM
