EGT's
Old Aug 5, 2007 | 08:47 PM
Neal 97 250's Avatar
Neal 97 250
c00n I have gotten confused on ths several times and have been set straight. The less resistance the more fuel/power. Trust me. Someone help me explain. I quoted this from the linked website. see below:
A 10k ohm resistor will raise the injection oil pressure approximately 200 psi. Increased injection pressure will deliver more fuel and will deliver more fuel sooner. This increase in fuel deliver and advance will yield higher combustion temperature but your exhaust gas temperature will remain almost steady. Such an efficient burn has it's down side. It will cause an idle rougher than stock. It may also cause the production of nitrous oxides. Thermal efficiency is a function of the high(absolute)temperature divided by low(absolute)temperature. In other words, the higher the peak combustion temperature in comparison to the exhaust temperature the more efficient is your engine.
http://pages.prodigy.net/stevebaz/_i...az/index3.html
Old Aug 6, 2007 | 11:24 AM
tjbeggs's Avatar
tjbeggs
Less resistance equals more power. I have a 1K resistor in mine but its for helping out with my lope idle that I can't figure out. It doesn't affect my idle either. But anyway back on topic
Casey those temps seem too high to me. With just a 10K mod you might have something else going on. Was the engine luggin when you saw those temps? the engine will create more heat luggin at low rpm then it will high rpm. Usually dropping a gear will help reduce EGT's. How is your air filter and fuel filter? have you checked fuel pressure lately?
Old Aug 6, 2007 | 11:57 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Arrow
Originally Posted by caseydudem
My gauge is installed pre turbo. Going 70-75 mph I think the rpms were between 1500 and 2000 rpms in overdrive. The egt level was 1200 degrees on hills. That is were it starts to go in to the red danger zone.
You can drive at 1250* all day long as IH says. but you can try what TJ said, take of the OD an check thouse EGTs. BTW with a CHIP you can use 40 tow and that lowers the EGTs and you dont need any more the 10 k mod.
TJ, do you have a 1K or a 10K resitor??
Old Aug 6, 2007 | 12:00 PM
tjbeggs's Avatar
tjbeggs
its a 1k, 1000 ohms. Don't ask why cause I don't know other than it makes my truck not lope like a pulling truck at start up. It has a 10K pot hooked up when I bought it and it would lope in anything higher than 1k so I just put in the 1k resistor like a 10k mod and it works. I think its a quirk of running split shot injectors on single shot programming. So I just got in some AO injectors to DIY into some stage 1's when I get some time and money.
Old Aug 6, 2007 | 02:27 PM
caseydudem's Avatar
caseydudem
Correction
My RPM numbers were too low. I was moving at about 70-75 MPH and that puts my rpm at about 2200 give or take some. I dont think it was lugging. It actual seemed to be running really smooth. When it gets up that high she really purs, but that dosn't answer my question. The fuel filter is brand new. The air filter comes due for replacement at the end of the year. I dont have any suggestions but I dont think those are doing anything to hinder flow. I have not checked fuel preasure. I guess I need to get the right tool and do it.
Old Aug 6, 2007 | 02:53 PM
DAVID'S97F250HD's Avatar
DAVID'S97F250HD
If you were going up a hill and really had your foot into the pedal you'll see the temps climb.
Do you still have the stock down pipe and CAT???
Old Aug 6, 2007 | 02:58 PM
caseydudem's Avatar
caseydudem
My foot wasn't in it at all. It was on CC. I have a full flow exhaust system. No cat, no restrictions. My dp is 3.5".
Old Aug 6, 2007 | 03:12 PM
RocknXJ's Avatar
RocknXJ
Awhile back I did a test about stock EGT's, before I had an intercooler. I towed the same hill with the same load two weekends in a row, so the second weekend I put the tuner back to stock to see what the EGT's would be. I could still run over 1300* at will once I was about halfway up the hill. This was with only a Tymar intake and a 4" exhaust, no other mods. It surprised me that I still had to back out of it with the stock tune.
I think folks with no gauges run temps like that and don't even know it. I also think we can run higher temps than most are willing do without any damage.
The lower RPM's will have an effect on EGT's, down shift and they'll go right down.
Old Aug 6, 2007 | 03:35 PM
DAVID'S97F250HD
Going up a hill with CC will still supply more fuel if its sensing a reduction in speed because the truck wants to maintain the speed the cruise is set at. Try shutting off your over drive before incountering a big hill and see if your temps will fall. Then when your finished pulling through and platue the hill. shift back in overdrive and keep going.
Old Aug 7, 2007 | 02:46 PM
caseydudem's Avatar
caseydudem
Wink
Okay so even if my rpm was at 2200 already I should take it out of over drive for the hills then put it back after. I'm not sure if that would work. My rpm's are going to be pretty far up there. Maybe this will just have to be my excuse to get an IC.
Old Aug 7, 2007 | 03:01 PM
nighthawk285's Avatar
nighthawk285
I hate to say this, but you could always slow down once you shift down
Old Aug 7, 2007 | 05:34 PM
DAVID'S97F250HD
Very true, your doing 75mph up a hill pulling a trailer woundering why the EGT's are climbing, the issue is your working the engine hard and the egt's are through the roof, the things you have against you is:
1. your cruising at 75mph
2. your pulling up a hill.
3. your pulling a trailer(even though its not meeting your max load rating, still is a larger drag)
Old Aug 7, 2007 | 09:17 PM
  #28
Neal 97 250
True grab a lower gear and see what she does. It should lower egt's
Old Aug 8, 2007 | 01:45 PM
  #29
caseydudem's Avatar
caseydudem
Yeah
You guys are right I probebly shouldn't be towing at that speed, but I was trying to get home for prior engagments. Anyways thats not the question. The question was why my egts are so high when the truck is only stock. I can see this happening easily on a chipped or programed truck, but mine is stock and has full flow capabilities on both ends(intake and exhaust). This is what doesn't make any sense. I normally dont even pull close to that speed. It hurts my fuel millage too much, but I should be able to and I know a lot of guys who do. That is the problem I would like to resolve.
Old Aug 8, 2007 | 03:36 PM
  #30
DAVID'S97F250HD
I remember someone else going through the same thing on a stock or nearly stock motor so you would'nt be the only one.
