door locks
Old Aug 5, 2007 | 10:43 AM
diggum73's Avatar
diggum73
door locks
ok so i know these damn things go bad and i have printed out how to fix it when you get lock act. out but how the hell do you get the act. out. jsut came in from looking at it and moving it around but was afraid to pry and break it of. any help here would be great.
Old Aug 5, 2007 | 12:14 PM
ReAX's Avatar
ReAX
I take it you have the mechanism out and are trying to separate the latch from actuator.
The actuator has a little tab that clicks into the latch and slides of some brackets. I am going from memory here, but the actuator is perpendicular to the latch and slides across the flat side of the latch. Release the tab and slide.
Old Aug 5, 2007 | 01:05 PM
diggum73's Avatar
diggum73
no worries got it all out and opened up the lock the motor and wraped with foil. but still nothing. maybe motor burned out. how sad for me of course this would not work on mine. grrrr
Old Aug 5, 2007 | 01:09 PM
ReAX's Avatar
ReAX
If it's all of them, when my VSM took a dump, it took all of my door locks out. If it's just one, then your VSM is fine.
6L3Z-25218A42-AA RH
6L3Z-25218A43-AA LH
These are the ones I used on my SD.
Old Aug 5, 2007 | 01:42 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Just go and buy one on ebay for cheap and it worked out great for me.
Hope this helps,
Nick
poulton
Mar 4, 2015 11:16 AM
TexasGuy001
Jul 17, 2012 03:23 AM
gtajw
15
Jan 10, 2012 09:36 PM
97-psd
May 12, 2009 08:44 PM
Knucklebuster
Jan 18, 2007 03:16 PM
