E40d problems...
Old Aug 4, 2007 | 03:33 PM
bobfromktown's Avatar
bobfromktown
Exclamation E40d problems...
My tranny is actin up really bad, first it was just holding a gear for a little bit and then pushing into the next gear and now the speedometer is really actin up, like jumping around really bad. If anyone knows anything I could really use the help
Old Aug 4, 2007 | 03:42 PM
Skandocious's Avatar
Skandocious
Your VSS might be bad, or your speedo cable might need to be greased.
Old Aug 4, 2007 | 03:43 PM
bobfromktown
What is the VSS?
Old Aug 4, 2007 | 03:53 PM
Skandocious
Vehicle speed sensor, I believe it is mounted to the side of the E4OD (depending on your year truck... what year it is?) although I'm not sure where, I've never had to do anything with it. My buddy just replaced his the other day because of a bouncing needle and strange tranny shifting (hmm, sounds familiar ehh?) It didn't fix his problem actually... Someone made a comment about how the VSS only sends its signals for the ENGINE to use, not the speedometer. But who knows, maybe the VSS is bad. Here's Jurgen's thread about his transmission:
https://www.ford-trucks.com/forums/6...ensor-s-2.html
How about some specs on your rig?
Old Aug 4, 2007 | 06:30 PM
jroehl's Avatar
jroehl
'92-up trucks have the VSS in the pumpkin (differential), and don't have a mechanical speedo cable--it's all electronic. Pre-'92, the speedo was mechanical, controlled by a cable into the rear of the tranny, with a separate VSS to control the RABS.
Jason
Old Aug 4, 2007 | 06:56 PM
Skandocious
Oh okay. I knew about the VSS moving to the rear diff in 92 but I didn't know the speedo cable was eliminated. Good to know
Halfpiece
Apr 23, 2014 07:52 PM
PstrokeN
Nov 16, 2010 11:19 PM
84 f250 6.9
Dec 28, 2009 11:49 AM
hi mile ford
Aug 16, 2009 07:50 PM
sachmoe_
2004 - 2008 F150
Jul 5, 2009 10:48 PM
