powerstroke diesels donrt have a tps do they? my 99 is actin up when u give it pedal it some times does pick up it almost dies then com,es back and its normal iirc thats what the CPS does when its outta wack?
would that make the truck wanna die then come back to normal and when you push the pedal down or even at idle it sometimes acts like it will die and not rev up then goes back to normal or is that the cam sensor?
