351W/302 differences
Old Aug 3, 2007 | 01:03 PM
rattosh51's Avatar
rattosh51
Gents,
What's the easiest way to tell a 351W from a 302 when installed in an '87 F150? Got a mystery truck that I picked up and the kid who owned it said it was a 351, but it sure looks like a 302 to me. Doesn't make a difference to me, just trying to clear it up.Thanks,
Old Aug 3, 2007 | 01:11 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by rattosh51
Gents,
The 8th digit in the VIN is the engine code.
1987: H = 351W / N = 302
Old Aug 3, 2007 | 01:12 PM
Kemicalburns's Avatar
Kemicalburns
well in 87 the 302 would be efi first. while the 351w would be carbed. also another way to tell is down by the distributor on a 351w the base sits below the intake vs flush with the intake.
Old Aug 3, 2007 | 02:34 PM
rattosh51's Avatar
rattosh51
Thanks, guys...it's a 302 like I thought...it has efi. Supposedly the engine was swapped, but I don't think so...looks original.
Old Aug 3, 2007 | 03:21 PM
Kemicalburns
what shape are the runners on the upper intake. a 302 has square looking runners while the 5.8 has round runners. 351w became efi in 88 but any efi 5.8 could be swapped into a previous efi 5.0 equipped bronco/truck. does the egr tube come from the passenger side manifold up to the upper intake/throttlebody area or does the egr tube come from under the upper intake then up to the throttlebody area??
Old Aug 3, 2007 | 04:24 PM
baddad457's Avatar
baddad457
The 5.8 upper is plainly cast that way: 5.8 EFI.............
Old Aug 3, 2007 | 05:40 PM
EPNCSU2006's Avatar
EPNCSU2006
^ not all of them were. The earlier EFI 302 and 351 both had Ford Electronic Fuel Injection cast into them instead of the engine size. The later models had either 5.0 or 5.8 cast in.
Old Aug 3, 2007 | 09:31 PM
baddad457's Avatar
baddad457
Good to know,ain't run across those yet.
Old Aug 4, 2007 | 09:52 AM
Conanski's Avatar
Conanski
A couple more numbers to help differentiate the motors..
Intake width is 9" on the 5.0, about 12" on the 5.8.
Deck height is 8.2" on the 5.0, 9.5" on the 5.8.
Old Aug 5, 2007 | 01:04 PM
pud's Avatar
pud
easiest way to tell is to look where the dizzy clamp is, if the block deck that it (the dizzy clamp bolt) threads into is flush with the bottom of the intake then its a 302 like kemicalburns said. On a 351w theres a definate difference in elevation between the two..something like 1.25"
Old Aug 6, 2007 | 12:59 PM
rattosh51's Avatar
rattosh51
OK, the egr comes from under the upper intake, up to the throttle body, and yes
it does have the plain "Ford Electronic Fuel Injection" casted on it. The dizzy does look to be elevated from what I can see...so 351W after all?
Old Aug 6, 2007 | 08:32 PM
Conanski's Avatar
Conanski
OK, the egr comes from under the upper intake, up to the throttle body..
That's a 302, the 5.8 lower intake is not plumbed for EGR.
Old Aug 6, 2007 | 09:09 PM
petes79f150's Avatar
petes79f150
The ports entering the front of the block from the water pump on a 302 are right up against the deck, down about an 1 1/2" on the 351.
Someone should make these into a sticky.
Pete
Old Aug 7, 2007 | 09:59 AM
rattosh51's Avatar
rattosh51
Thanks all....didn't think it would be that hard. I agree with making this
a "sticky" as I did a search and this does come up quite often.
Shwan_89HD
26
Jun 11, 2023 05:02 AM
sandhillmike
May 29, 2006 04:00 PM
stats2me
Nov 4, 2005 08:26 AM
FordCrazy1970
Sep 21, 2005 06:42 PM
retread
Feb 16, 2004 03:11 PM
