the 351w and 302 are very different. 1-the 351w has a taller deck height than the 302. 2- since the deck height is taller the intake maifold is wider on the 351w than on the 302. 3-the 351w uses a larger main journal than the 302.
i have all the numbers at my shop if you need them i can post them tomorow.
Watch out for the 73-76 302, they have a different deck height. 73-76 used a 8.229 height insted of the 8.206, which makes it lose 1.4:1 in compression.
