Need Grille Information
Old Aug 2, 2007 | 04:03 PM
timsexcursion's Avatar
timsexcursion
My son informs me 'Dad I hit something and put a hole in your grille'...
I need to know what grilles fit my 2000 Excursion. Do all superduty grilles fit it? What years? I don't care if it is an original (ie. Excursion only) or not. Just need a good used one. Thanks.
Tim
Old Aug 2, 2007 | 04:10 PM
rbloodhound's Avatar
rbloodhound
The same year model superduty grill will fit. I just ordered a billit grill insert off of ebay for $85.00. I havent received it yet. It is the type that bolts over my stock grill.
Old Aug 2, 2007 | 04:23 PM
RCKYMTN-PSD's Avatar
RCKYMTN-PSD
99 - 04 should be all interchangeable, Super Duty or Excursion
Ive got a spare Excursion grill (black), if your near Tampa
Old Aug 2, 2007 | 04:54 PM
timsexcursion
Thanks for the offer...I'm in Vermont and leaving in 5 days for a 4 week trip...wouldn't you know...
I need a chrome grille and will need to find one locally. I just need to know what year(s) superduty grilles fit mine. I'll probably just go to a salvage yard.
Old Aug 2, 2007 | 07:30 PM
1's Avatar
I say its as good a time as any to get the 05 excursion grille modified to fit on the older trucks. They look great, original quality, and price isnt too bad.
Old Aug 2, 2007 | 08:10 PM
timsexcursion
What would the price be for an '05? What kind of modification is required? Do you have to buy the '05 bumper too? I would like to replace it with an excursion grille but figured there aren't that many around and would have to settle with a superduty grille. Maybe I'm wrong...
Old Aug 2, 2007 | 09:42 PM
Monsta's Avatar
Monsta
Sit. Stay.
Those eggcrate sections on the Excursion grill are replaceable. Might wanna check ebay for a set. I seen them often.
Of course, if it's the chrome frame that is broken then my post ain't worth .02.
Old Aug 2, 2007 | 10:03 PM
i eat hybrids's Avatar
i eat hybrids
You could just get a grille from stylin concepts. I have one and it looks alot better then the stock one. Pics in gallery.
Old Aug 2, 2007 | 10:35 PM
timsexcursion
I had no idea the 'eggcrate' part of the grille was replaceable by itself. The chrome on mine is good. I'll check it out...
Old Aug 3, 2007 | 11:04 AM
1948f1's Avatar
1948f1
2005-2006 grille that fits 2000-2004 model
I purchased an 05-06 grille modified for a 2000 model from this supplier and am very pleased. These are the cheapest I have seen on eBay and it will completely update your front end in 10 minutes with no cutting. You just use your existing tabs. http://cgi.ebay.com/CHROME-FORD-SUPERDUTY-GRILLE-F250-F350-SUPER-DUTY-GRILL_W0QQitemZ330152404610QQihZ014QQcategoryZ3364 5QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Old Aug 3, 2007 | 01:58 PM
fatswany's Avatar
fatswany
Looks pretty shweet. Last winter I caught a fist sized rock, (it was still wedged in the grill) took out the small insert and broke the vert section of the frame between the insert and the main grill. Been stalling replacing till I found something I couldn't live without, this might be it.
Old Aug 3, 2007 | 04:06 PM
1948f1's Avatar
1948f1
The modification on this grille does not effect you being able to add billet inserts, so you can add that personal style to your truck if OE is not enough.
Old Aug 4, 2007 | 01:27 AM
timsexcursion
Originally Posted by chelle26
..there are kinds of grilles including chrome and phantom grille. either ford grille or OEM, be sure to have knowledge about the kind and what type of grille application needed. also factory ford grille or performance ford grille has all that it takes for you to choose.
Ok, not sure what a phantom or performance grille is...just need to find something here in 2 days in the boondocks of Vermont...appreciate everyones help.
Last edited by Y2KW57; Oct 11, 2024 at 02:43 PM. Reason: Quoted portion of post edited to remove commercial advertising link
Old Aug 4, 2007 | 01:52 AM
Monsta's Avatar
Monsta
Sit. Stay.
Inexpensive billet inserts. They replace the OEM ones.
http://cgi.ebay.com/ebaymotors/99-04...spagenameZWDVW
Jenksie13
6.7L Power Stroke Diesel
Apr 6, 2018 08:46 PM
GTRider
Jul 13, 2016 10:08 PM
MrDad1
Feb 22, 2008 11:40 AM
RedTaurus94
Apr 7, 2005 07:14 AM
fhartell
Dec 18, 2003 10:49 AM
