Oil Sample results
Old Aug 5, 2007 | 12:43 PM
  #31
ernesteugene's Avatar
ernesteugene
Originally Posted by jrciii56
You can get free oil analysis with Schaeffer and you can buy a vampire pump that will stick tube down you dipsick hole to pull the oil so that it can be collected. In other words free and little labor.
I would NEVER trust the health and longevity of my PSD to any results given for FREE, including the ones you get from my free analysis of "how things work" here on FTE! Lately it seems that you seldom get what you actually pay for, and it's been my experience that you almost never get what you don't pay for.
But no matter how much additional labor and cost is involved to do oil analysis, no one can claim that just changing it every 3K or 3 months isn't better for the engine, and when you do a cost comparison, you can't save more than a few % in operating cost, and that comes with a risk that if you wind up going too long between changes you can do short term damage to your engine.
Old Aug 5, 2007 | 12:49 PM
  #32
ernesteugene
Originally Posted by strokin_it7.3
For me its not so much of a cost factor, it's peace of mind knowing exactly what's going on inside my engine. The extended oil drain intervals is just a bonus. Analyze that.
If one of my blood test reports came back like your last extended drain interval oil analysis report, I wouldn't consider it a bonus! At 65, I just wish I could change my blood like I do the oil on my PSD!
Old Aug 5, 2007 | 01:02 PM
  #33
SpringerPop's Avatar
SpringerPop
Eugene,
The method you're suggesting sounds a little like:
Religiously take your blood pressure pills.
Never take your blood pressure.
This is as opposed to:
Take your blood pressure frequently, but don't take the pills unless it's elevated.
Pop
Old Aug 5, 2007 | 01:13 PM
  #34
JIM ROLAND's Avatar
JIM ROLAND
Re: www.bobistheoilguy.com.......Duralube used the same test on T.V. I run about 2 of my 15 quarts with Duralube, a little more protection but not overdone. I have 140k on my 2000 7.3 psd and change every 4k. I also use Z-max in the transfer case, trans., rear end and engine with every other oil change, BUT when I use the Z-max I DO NOT use the Duralube. If you choose to run the Z-max, buy the large kit which has the additives for all areas. It's a little confusing as to what to put where, so I called the Z-max # on the bottle and the guy got me straight as to where and how much etc. to use in all areas. I run Rotella or the motorcraft oil only. Soooo....what do you guys think???
Old Aug 5, 2007 | 03:50 PM
  #35
bdrummonds's Avatar
bdrummonds
Originally Posted by ernesteugene
So you're telling me it's LOGICAL to crawl under your truck to collect oil samples (how many times between actual changes?) and pay (how much?) to have them analyzed, just to save at most a couple of percent (if that much when you compare the cost of syn vs dino) on your routine driving cost, and all the while you're putting the longevity of your PSD at risk?
I for one am not into the extended intervals. I change my oil at 3k if the fiver has been behind the truck for ~800 or more. If I have not been towing then I will change at 5-6k depending on free time. these are the same guidelines set forth in my owners manual. I have a UOA done twice a year (sample taken at oil change) just to have a little idea of whats going on inside the engine. I have used Delo 400 15W-40 dino, exclusively since I bought this truck w/ 10k miles in 2000. I have never used any oil additive. I have also had my tranny fluid tested to see if the level of abrasives (from the clutch material) was elevated and try to get an idea of how much longer my original stock tranny will last.
Old Aug 5, 2007 | 07:42 PM
  #36
Mach1's Avatar
Mach1
You can use an OA for several things, some being to establish OIL Change interval(by looking at the numbers-I am at 10000 OCI), As a preventative maint issue I.E. Is your air filter/intake working still(this is critical because a leaking intake can dust an engine in NO TIME Flat..
Old Aug 5, 2007 | 07:43 PM
  #37
ernesteugene
Originally Posted by SpringerPop
Eugene,
Pop
What I've been trying to say is to change your oil more often so that you won't damage your PSD, which would drive up your blood pressure, and require you to take pills!
Old Aug 5, 2007 | 07:54 PM
  #38
justblowin'smoke's Avatar
justblowin'smoke
I change the oil in my truck every 5,000 miles, the oil comes out black but not black as coal though if the chips have been turned up and pulling trailers. just driving around keeping my foot out of it, the oil is only brown to slightly black but i havn't seen this since the second oil change. also everyone thinks black smoke is cool and all but it does wash down the cylinder walls causing excessive wear this is y i seldom run the smoker setting on the hypermax tuner and the amount of smoke my truck does make cleans up after the turbo kicks in
Old Aug 5, 2007 | 09:42 PM
  #39
Tenn01PSD350's Avatar
Tenn01PSD350
I've said it before, I'll say it again. I do not do OAs. I do check my intake, filters etc. What would I do when I got back the results? Go back and look at what I check anyway, filter and intake setup? Lets say my OA #s begin to indicate possible ring or bearing wear. What now? Hand wringing? Stress pills?
How about I just change my oil at a max mileage interval of 4k or at the moment it no longer looks golden brown on the stick? That's my story and I'm sticking to it. I have never gone wrong doing that.
Your mileage may vary, especially since I do not rack up that many miles anyway. I have even changed honey colored oil because I felt it had been in there too long what with oxidation and the byproducts of combustion and fuel etc in the oil. I have done this at 6 months when the oil has had less than 2k on it. It's just not worth it to me. Better safe than sorry.
OAs are a tool, be careful how you use it is all I want to say. Most here appear to use it properly. It's just not for me.
Old Aug 5, 2007 | 10:02 PM
  #40
John311t's Avatar
John311t
I agree 100% with tenn, I even have a sample kit which is going to sit on my desk forever. I think if you do the OA's you must be calm minded, because I couldnt handle seeing bad things on the OA. I was told my injectors are all going to crap out soon due to gelled fuel, and the damage from it happening 5 times and driving with fuel pressure at 10psi(this happen 3 of the times) because of gelled fuel. What happens is gonna happen anyways, something else ive learned is that mechinical things dont usally just go boom(im not talking about hipo motor running the strip), they will show signs of something getting worse and worse, like my first injector replacement, it got worse and worse and worse, thats when i knew to replace it.
The same reason I hate the doctor! I only go when I am really sick.
Old Aug 5, 2007 | 10:07 PM
  #41
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Any moderators reading this, feel free to close this thread, as it's turned way south of how i expected it to...
Old Aug 5, 2007 | 10:21 PM
  #42
Tenn01PSD350
Well, got my oil sampled, thanks JTharvey for sending me the bottles
Not so good news... lots of lead... Bearing wear... I am planning on changing the oil and the OG filter as well... What does everyone think about Schaeffer oil products? I was going to buy the 5w40 from Bean's diesel.
C'mon Kris, what do you expect when you ask about this? Yep, get Schaeffer and have a nice day? You've been here long enough to know better. No need to close the thread as many are forming opinions about OAs.
Myself, I have been amazed at where a thread can go. As a matter of fact, I am still trying to figure out what is happening to mine since changing to Delo, getting the DP tunes, dyno, drag strip and 2300mile trip. I think the truck has started using oil. I have never had to add oil between changes but put 2 qts in this go around. Sadly, it is the same oil I put in right before you got here. It is getting changed this weekend. BTW, I am on my weekend now. Positive note, oil is still honey colored on the stick, but it is going.
Old Aug 5, 2007 | 10:33 PM
  #43
clux's Avatar
clux
/Snip/
I do an oil analysis every oil change (10,000-12,000 miles) and it costs $22 and takes under 5 minutes of my time. I can and will claim that doing an oil analysis is better than changing my oil every 3000 miles. The original poster is seeing high wear metals on a moderate change interval (5000) and is trying to locate the source of his problem. Will a 3000 mine OCI solve his high wear metal problem?
Does your 3000 mile oil change tell you how much fuel dilution you have in your oil? Can fuel dilution be damaging?
Does your 3000 mile oil change tell you if there is small amounts of coolant in your oil? Can coolant in your oil (even a small amount) be damaging?
Does your 3000 mile oil change tell you anything about how your engine is wearing? How do you know that a 3000 mile OCI is often enough under the conditions that you operate?
Changing your oil is giving you a feeling of well being, but there's no way you can claim that every 3000 miles is better, as without oil analysis you have no data to back it up.
Old Aug 5, 2007 | 11:03 PM
  #44
Tenn01PSD350
Clux, your point is well taken and makes sense. We've gone around on this in the past and each time I learn something new. Now Kris is pulling his hair out I'm sure.
Does your 10-12k oil change and sample interval tell you that you have coolant or fuel in the oil that occurs in the first 100 miles since change, and does it do it in time? Do you figure that you are better off knowing that you have a bad injector cup or injector Oring and it may have happened 10k miles ago?
On the other hand, I have no idea I may be having a problem unless I see something obvious, but at least I am changing it more frequently. Perhaps an occasional OA would not be bad to at least check for fuel and coolant in there. As for metal wear, nothing I can do about that. I SAY AGAIN, if there's no fuel or coolant in the oil, and the filter is good, NOTHING I CAN DO ABOUT EXCESSIVE METAL WEAR. Back to hand wringing, and then, perhaps a Cummins.
So I acknowledge your point, can you acknowledge mine about extended oil intervals?
Old Aug 5, 2007 | 11:14 PM
  #45
PowerstrokeJunkie
Cummins' have bearings too?
The point i was getting at.. was that i did NOT ask nor WANT a technical analysis of my oil analysis results, how spending the $32.50 and using a 5500 mi OCI will cost me 8.25437% more to drive my truck as opposed to changing my oil every 3000 miles and not doing an analysis. My point being that i do it because i want to, and there is no need to bring in every aspect of cost and value and use long equations to justify your point, i do an oil analysis because i wanted to, i care about my truck and like to know what's going on inside it.
