Priming a flathead
Old Aug 1, 2007 | 07:50 AM
john fin's Avatar
john fin
Priming a flathead
Is there an easy way to oil prime a flathead.
Old Aug 1, 2007 | 08:03 AM
cts1954's Avatar
cts1954
Priming a flathead is not as easy as a small block chevy, you need a few pieces of duffle to make it work. You have to connect into to the oil circuit at the back of the block, where the oild pressure sensor is connected, and you have to force oil through the system with either a pump or pressurized tank. I made a rig out of an old oil furnace burner pump and motor and it works good, I put a plastic pail resorvoir on top and the gear pump injects the oil into the block at 70-80 psi on my engine. I will post some pictures of it today in my gallery if you are interested. There are other methods that guys use and I am sure there will be lots of ideas. I certainly is a good idea to do this after your engine has been sitting for a while as by experience these flatheads are expensive to rebuild.
wgc
Old Aug 1, 2007 | 08:20 AM
john fin's Avatar
john fin
Yes I would like pics of that device. I am not sure how I could get that oil injected, I dont have a pump.
Old Aug 1, 2007 | 08:46 AM
mtflat's Avatar
mtflat
That's the best way.
Don't make the mistake of pre-filling the oil filter canister. At least that's what the old flathead guys will tell you.
D Sokol
Jun 15, 2016 09:55 AM
ssj7kids
Jun 2, 2010 11:03 PM
Fat Fendered Ford
May 1, 2009 05:52 PM
nickmobile67
Flathead V8 & Flathead 6
Jan 13, 2003 04:04 PM
jearl
Jan 1, 2003 03:49 PM
