Left Engine Bank not getting fuel
Old Jul 30, 2007 | 06:49 PM
forresteye's Avatar
forresteye
2001 7.3 power stroke
I was driving down the road and my left engine bank quit getting fuel. I know this because the truck lost power so I pulled over and did the following.
Drained water seperator
Changed fuel filter
I then let the engine cool down. I could drive about 40 MPH so I went to the closet Auto Zone. While on the way I saw that my pyrometer was only reading 200. The pyrometer is located on the left side. The guys at Auto Zone put their code reader on the truck but no codes came up even though the check engine light was on.
So got the truck home called some guys and looked at this forum. Check the wires outside the valve covers and inside the valve covers and can not find any raw wires. Put the ohm meter on them and found all to be connected and none to be crossed.
Any suggestions?
Old Jul 30, 2007 | 07:04 PM
15 and 92 Dad's Avatar
15 and 92 Dad
I wish I could help, but the one thing I have found out is that the OBD II code readers that autozone, orileys and others do not work on our diesel trucks, most of them are not aware that they dont work! They hook up, no codes, must be good, wrong!
Just a thought, might need to get a dealer or someone with A.E to give it a look.
Rich
Old Jul 31, 2007 | 08:54 PM
Sabre2th's Avatar
Sabre2th
Lack of fuel to one bank only will most likely turn out to be the UVC harness has come loose (Under Valve Cover) and it's not firing the injectors, or the small screen in the fitting where the fuel line attaches to that head has gotten clogged..
Just my .02,
Tom
rollinblackcloud
May 1, 2014 09:10 AM
pullinhorses
22
Feb 13, 2010 01:51 PM
Onsiteservice
100
Feb 5, 2010 09:23 PM
troddleboy
18
Feb 13, 2007 05:43 PM
INANDOUT11
13
Dec 21, 2006 06:22 PM
