Welcome fellow Maconite!! Sorry I'm no help with your vin but Bill will chime in soon enough! Nice to see another local come on. Be sure to check out the Ga. chapter on here if you haven't yet!
Just bought a 64 flareside. Can someone decode for me, please?VIN: F10CE514639
The rest of the tag is pretty-much painted over, but it looks like:
114 L F100 381 A 12
5000 135 3800 22
What's it all mean?
TIA~ Rob
Welcome to FTE
F10 = F100 2WD
C = 292 2V
E = Mahwah NJ Assembly Plant
514639 = 1964
114 = 114" Wheelbase
L = Holly Green
F100 = F100 2WD / 5,000 lb. GVWR
3 = Medium Green Crush Vinyl / Medium Green Rib Vinyl
81 = 81A Standard Cab
A = Ford 3 Speed All Syncro Manual Transmission
12 = Ford 9 Inch Rear Axle / 3.89-1 / non Limited Slip / 3300 lb. Rear Axle Capacity
5000 = 5,000 lbs. GVWR
135 HP @ 3800 RPM
22 = Charlotte NC Ford District Sales Zone
Wow. Thanks for the welcome, guys! And thanks for the info, Bill! Just got it home from SC yesterday. It's now burgundy with a black interior and red seat.
Hey, were 3 speeds from this year always on the column? It has a hole in the floor for a shifter as well as the stick on the tree.
Mine has a hole in the floor as well, but someone did it as they put an aftermarket shifter in. Was back on the column when I got it.
What size "hump" is your transmission tunnel? Two different ones where offered as per trans type.
Is it still a 292 under the hood? I've done alot of work to mine, that you cannot see, suspension rebuild, motor, anti-rattle kits in the doors, cooling system, yada-yada-yada. She is still a heap, but I can drive her anywhere!
Still has the 292. Now that I look closer, the hole definitely looks like a DIY job. I don't have anything to compare it to, but the hump looks pretty short. Maybe 2 inches? Some pics in the gallery soon.
