Sponsored by: Auxito
ABS code C1096 (fixed)
Old Jul 29, 2007 | 09:37 PM
fatforty's Avatar
fatforty
ABS code on a 2000 F150. Code was C1096 Hydraulic pump motor open circuit. I asked the local Ford dealer about it and he said I needed a breakout box to test it. I went back to the old way and started looking for broken wires and bad sensors. I tested for voltage in the wires just before the pump motor and had voltage, I thought the motor must be bad but when I tried to unplug the short harness one of the wires came off of the motor and green corrosion came out of the wire. I took the airbox out to get to it easier and removed all traces of the wire in the motor. I tinned the wire that was left (in good shape) and re-soldered it to the motor. Started the truck and the light is gone. thought maybe this might help someone else before going to the Ford dealer to have it checked and fixed.
Old Jul 30, 2007 | 01:33 PM
KingRanchMan02's Avatar
KingRanchMan02
Good job fatforty! Thanks for passing on your experience!
mini_blaine
1997 - 2003 F150
Jul 18, 2017 09:45 AM
kehoeautomotive
May 2, 2012 10:18 AM
SuperMike
Jan 23, 2012 04:03 PM
JohnsonFord
Jun 1, 2011 07:34 PM
BltFordTough
Oct 30, 2010 05:18 PM
