Sponsored by: Real Truck
ABS Light On Multiple Codes
Old Jan 23, 2012 | 04:03 PM
SuperMike's Avatar
SuperMike
I have a 2004 F250 XLT 4x4 5.4l with 135k miles and the ABS light popped on last weekend. I bought and hooked up a Actron Brakescan to my truck and it popped out 7 codes:
B1676 Battery Pack Voltage Out Of Range
C1185 ABS Power Relay Output Circuit Failure
C1096 ABS Hydraulic Pump Motor Circuit Open
C1095 ABS Hydraulic Pump Motor Circuit Failure
C1198 ABS Inlet Valve Coil LF Circuit Failure
C1214 ABS Inlet Valve Coil RF Circuit Failure
C1202 ABS Outlet Valve Coil Rear Circuit Failure
The first code about the battery voltage is from about 2 months ago when my re-manufactured alternator took a crap early one morning and the original battery tapped out and left me stranded at an intersection. The worst part is that some (nice) guy in a Dodge Ram was all to proud to tow me into a parking lot.
So what do you guy think needs to be done? A new ABS Hydraulic unit and or a ABS Control Module??
TallTexan
Apr 20, 2015 07:44 PM
BltFordTough
Oct 30, 2010 05:18 PM
71FoMoCo
1983 - 2012 Ranger & B-Series
Aug 25, 2010 04:13 PM
RA81222
1978 - 1996 Big Bronco
Dec 2, 2007 07:29 PM
bronco5.8
Jun 28, 2005 09:57 AM
