Old Jan 14, 2001 | 05:50 PM
breez's Avatar
breez
Have a 93 351 with a auto. Need more h.p. for trailer pulling. Where is a good place to start and what is a good plan of action. Would prefer bolt on help. Thanks.
Old Jan 15, 2001 | 12:00 AM
hpguy's Avatar
hpguy
Well, the road to supreme performance is paved with busted knuckles, and empty wallets, so prepare. The best, easiest performance mods are: intake/carb, headers and cam. If you go with a big change in the cam, then be prepared for a valve/head job.
It can get expensive, but do the mods one at a time, don't get in a hurry, and it should work out.
-Andrew
f250_64(No Email Addresses In Posts!), same for yahoo messenger
Nothing, and I mean nothing, stirs the soul, saying I'm a bad **** like lettin'em rip with a window shaking, fuel gulpin, carbon monoxide belchin, attention gettin, V-oh my LORD!-8!
Old Jan 15, 2001 | 08:57 AM
gostrider's Avatar
gostrider
I would look into computer chips or a vorteck super charger! I think it would be less work and won't change the fuel consumption as much. The gas prices are not getting any better! You can change the computer chip for probably under $300.oo A lot less work and less money for the increase in power. Look at other messages on the forum. There is good info that pertains to your needs.
Good luck
Scott
Old Jan 15, 2001 | 05:39 PM
billyb's Avatar
billyb
i would check your axle ratio. anything less than 3.55 probably causes problems when towing a load.
Old Jan 15, 2001 | 10:52 PM
daywalker's Avatar
daywalker
Do some research on which exhaust systems offer a boost in low end performance. Cat-Back systems and headers. That ol 351 can be a dog when pulling some things eh.
Daywalker
92' F-250 351 4x4 xlt 4.10 5spd sprcab lngbed
http://albums.photopoint.com/j/View?u=1426655&a=10683799&p=36629681&Sequence=0&re s=high
Old Jan 16, 2001 | 07:01 AM
breez's Avatar
breez
[font size="1" color="#FF0000"]LAST EDITED ON 16-Jan-01 AT 08:04 AM (EST)[/font][p]Ya it can be.The rear end idea sounds like the way to go also.4:11 would help.Any body ever change one in a 3/4 ton? Would exhust or intake be more helpful?
Old Jan 16, 2001 | 07:38 AM
Nathan's Avatar
Nathan
Them small blocks really need to breathe! A good cat-back exhaust, or even better, dual exhaust will really liven it up, even with stock manifolds. A high flow air filter will compliment the exhaust upgrade. 351Ws got some guts once you get rid of the factory restrictions.
Nathan
Old Jan 16, 2001 | 08:02 AM
DeenHylton's Avatar
DeenHylton
351
I have a good used set of 4:10s for a 3/4 ton if your interested. Ford as always been weak in the exhaust area...either they make them too big as in the Cobra Jets or too small in most of their production engines. Figure around $700.-$900. for headers with new dual exhaust system if you job it out. I wouldn't do the intake side till you've done the exhaust. Deen
Old Jan 17, 2001 | 11:49 AM
smackitup's Avatar
smackitup
oldford54
Oct 25, 2012 10:07 PM
maveric
21
Mar 22, 2010 04:12 AM
rsalter66
May 29, 2007 11:57 PM
flcbell
Apr 25, 2007 07:18 AM
travis c
Aug 13, 2003 07:52 PM
