351 Head Swap
Old Apr 23, 2007 | 11:50 PM
flcbell's Avatar
flcbell
351 Head Swap
I have a 351 with bad heads but a good bottom end. I have a pair of good used 400 heads. Will they work on the 351m engine.
Thanks
Old Apr 23, 2007 | 11:58 PM
unrulee's Avatar
unrulee
Yes, without a doubt they'll work.
Old Apr 24, 2007 | 05:27 PM
rowdy78's Avatar
rowdy78
they are the same head, nothing different at all
Old Apr 24, 2007 | 05:34 PM
unrulee's Avatar
unrulee
Yes they'll bolt right on with no problems....are they 100% identical, that I'm not sure on. But I wouldn't worry about it.
Old Apr 24, 2007 | 06:21 PM
grclark351's Avatar
grclark351
depending upon the years of the heads, you may or may not find A.I.R. passages for the emissions equipment. if you don't need the passages they can be plugged. if you need the passages for testing and/or visual inspection and they aren't there, you could have a problem...
Old Apr 24, 2007 | 09:44 PM
unrulee's Avatar
unrulee
I didn't think of that, but I live in ND, the land of 0 inspections .
Old Apr 25, 2007 | 07:18 AM
flcbell's Avatar
flcbell
Thanks for all the info no emisison needed. The swap will happen this weekend of course I will check valves out first.
happy fording
92nite351
Dec 21, 2010 05:48 PM
CharlieLed
Nov 10, 2008 12:01 PM
v10squirrel
Jul 10, 2007 08:54 PM
rsalter66
May 29, 2007 11:57 PM
travis c
Aug 13, 2003 07:52 PM
