351c 351m heads
Old Jul 22, 2003 | 07:08 PM
travis c's Avatar
travis c
351c 351m heads
also, if i put 351c heads on my 351m, would it increase compression/ performance? i have heard that the 351c was a higher performance engine
Old Jul 23, 2003 | 08:45 PM
dinosaurfan's Avatar
dinosaurfan
351c 351m heads
Yeah, I think you can help your engine if you get the right pair of heads. The 351C with the smaller chambers also has ports too big for the manifolds your 351M has. But there are small chamber, small port heads from austrailia that will do what you want. You might also mill .060 from the heads you have now and from the intake face of the heads as well. Don't mill the intake. you will also need shorter pushrods. More compression usually helps the 351M a bunch. DF
Old Jul 25, 2003 | 09:48 PM
travis c's Avatar
travis c
351c 351m heads
where can i get those heads from austrailia?
Old Jul 29, 2003 | 12:53 PM
TheFlex's Avatar
TheFlex
351c 351m heads
There used to be a company that advertised a hybrid aluminum intake for the above conversion. Look through Ford mags for the add.
Aussie heads are available used
http://www.murphysmotorservice.com/head%201.htm
Or from a head porter like Powerheads.
http://www.powerheads.com/351c.html
There is also a fancy aluminum hybrid piece but beware, they cost $2800 bare.
http://www.pavtek.com.au/pp_3vheads.html
Another option is to mod 4v heads to reduce the dead spots and increase flow. I have a set of these but have not used them as the car is in resto.
http://www.mpgheads.com/port_plates.htm
There are also a few companies that make adapter kits for the 351C manifolds to 400M blocks. Weiand does also.
http://www.pricemotorsport.com/Intak...nd_ap-30y.html
Old Jul 29, 2003 | 01:18 PM
Xmerwynd's Avatar
Xmerwynd
Cool 351c 351m heads
A 351 M can be easily stroked to a 400M by changing the crank to a 400M crank. 351C pistons and 400M pistons have the same compression hieght. However the pistons must be sleeve with a bushing as theare larger in the 400m than the 351. I know this works as I am building a "rat" engine for my '67 F100. You can use any 351C piston available. I used KB-177 (KiethBlack Hypereutechtik) but you can use normal composition or forged for a NOS setup, Drop me a line a Xmerwynd@Yahoo.com if you have any questions, I researched this deeply and can provide additional info if you need it.
Old Aug 3, 2003 | 12:39 AM
Ratsmoker's Avatar
Ratsmoker
351c 351m heads
Why are you putting a Big Block Chevy in your 67 F-100 man? My buddy bought a set of 5.0L heads from power heads. They do excellent work.
Old Aug 3, 2003 | 12:50 PM
TheFlex's Avatar
TheFlex
351c 351m heads
So that he could have a slow truck that needs to have the motor rebuilt every year.
Old Aug 13, 2003 | 06:49 AM
Xmerwynd's Avatar
Xmerwynd
351c 351m heads
The FORD 351/400 modified is a 100% Ford design and manufactured small block engine. It was marketed 1972-1978. The 351M/400M both use the smae raised deck Cleveland block. I am still buying parts for the motor build u and machine work as I get the extra cash. The heads have been ported and polished with 3 angle vale gring, comp roller rockers, comp extreme energy cam(duration 275/285). Block bored .040 as a daily diver, no chance of overheating due to poor heat transfer. KB-177 pistons, PAW balanced con rods, all ARp hardware, Mildon oil pump and 9 qt pan, Cloyes TRue roller timing gears & chain, Fluid damper, MSD-6AL ignition and distributor. I am held up for cash to have engine blueprinted balance. I plan to buy a TSi streetfighter transmission. What will it run in the 1/4, I do have have clue. To the flex My comment on the heartbeat of America was sarcasm, had you taken the time to readit. I am no Ford expert . However, I wanted to build a different motor than the 351W and FE family of big block Ford.
Old Aug 13, 2003 | 03:59 PM
ludis's Avatar
ludis
351c 351m heads
I guess you aren't aware of you "mistake": A "mouse motor" is a small block Chevy. A "rat motor" is a big block Chevy.
Up above you said you are putting a "rat engine" into your F100...
Old Aug 13, 2003 | 07:04 PM
Xmerwynd's Avatar
Xmerwynd
Red face 351c 351m heads
I stand hat in hand chastised. I am a senior boomer, to me a "rat" motor was the term used to describe any highly modified engine with out regard to manufacturer. I stand corrected and apologize for not knowing the proper definition for the 21st century. The last time I was involved with building a street rod was 1966.
Old Aug 13, 2003 | 07:52 PM
TheFlex's Avatar
TheFlex
351c 351m heads
Xmerwynd,
All is cool bro. The term you are looking for is rad or radical. I agree that a built tall deck from the Cleveland family is different. Lots of people shy away due to the cost, but the results can be impressive.
cruz76
Mar 26, 2006 05:40 PM
warecreek
Jan 25, 2006 10:08 AM
tastyklair
Jul 28, 2004 12:46 PM
jec27
Oct 20, 2003 08:32 PM
Billy Freeman
Jan 14, 2003 03:23 PM
