1989 F150 4.9l
Old Jul 26, 2007 | 10:34 AM
Dave13's Avatar
Dave13
1989 F150 4.9l
Good Morning,
My truck has been just dying lately. It will be running great then it will sputter a few times and just die. Sometimes it will start back up right away, other times I will have to wait an hour or so. I cleared the memory and kept running the truck until it finally died. The one code that came up is a CM code # 14. The code definition is "Two or more successive erratic Profile Ignition Pickup (PIP) pulses occurred, resulting in a possible engine miss or stall". I am not quite sure what that code definition means. Can anyone help ?
Thanks
<!-- / message -->
Old Jul 26, 2007 | 10:57 AM
F150xlt's Avatar
F150xlt
That's a common failure. The pickup coil needs to be replaced. Problem is you need to pull the distributor. The distributor gear needs to be pressed off along with the distributor shaft.
Easier to install a rebuilt distributor from Auto Zone, Napa, Parts America etc...
If you go the rebuilt route, make sure you transfer any parts needed from your old distributor to the new one before you turn your old distributor in for the core/exchange. I believe one of the parts is the octane rod.
Old Jul 26, 2007 | 11:58 AM
Dave13's Avatar
Dave13
Thanks, I really appreciate the answer. I will probably go with the rebuilt distributor.
Dave
Brody Olson
Jan 6, 2015 08:04 PM
Dr. Johnson
Sep 17, 2014 12:19 PM
countrysidemetalwork
Jul 16, 2014 06:36 PM
Watfordr
1978 - 1996 Big Bronco
Jul 9, 2014 05:53 PM
Matt Rucks
Mar 2, 2014 05:15 PM
