1978 - 1996 Big Bronco
Bronco issues :/
Old Jul 8, 2014 | 09:37 AM
Watfordr's Avatar
Watfordr
Bronco issues :/
Have a 1993 bronco 5.8 ran just fine for the week I bought it, one day I started it then it died once it died a burn wire smell came from the vent area and the bronco would not start back up. Could not find the burnt wire however it starts now but runs horribly and dies once I give it gas. Engine light is now on but can't get any codes from it. Also when the truck is in the accessory position engine not on the fuel pump make a whining noise unsure if that is normal. Any help? Thanks
Old Jul 8, 2014 | 11:19 AM
Kemicalburns's Avatar
Kemicalburns
fuel pump noise is normal. burning wire smell is not. really need to dig and figure out whats up. pulling codes is important as well.
Old Jul 8, 2014 | 04:40 PM
andym's Avatar
andym
I would guess that the burning smell was your PCM. Two of the most common symptoms of a fried PCM are the fuel pump runs constantly and the CEL comes on but there are no codes.
Try to get an actual Ford replacement computer either from a dealer or a junkyard. The aftermarket ones tend not to be as reliable.
Old Jul 9, 2014 | 05:53 PM
g_k50's Avatar
g_k50
Check the fuel pump relay and the wires running from and to the fuel tank.
drkfrnd
Bronco II
Jul 6, 2017 06:02 PM
Nashterbater
May 30, 2016 10:31 AM
skipalongrice
Nov 18, 2015 10:04 AM
arib
15
Jul 2, 2006 12:30 PM
rustyb
Jun 5, 2004 12:25 AM
