Mine reads to 999,999.9. I've got 277,000 on it. You didn't mention what year your's was. I think the older mechanical ones the numbers wouldn't line up right after it turned over 100,000 miles.
I'm curious what truck you have. '87-'91 read to 99,999.9 and '92-'96 go to 399,999.9. If you watch while the PCM boots at start-up you can see that the upper-left section of the left-most digit is missing, so it can't make a '4' (nor 5,6,8 and 9).
I don't think going by how the numbers align will tell you anything. The alignment of the numbers changes constantly as the larger numbers get closer to rolling over. Once they roll over, all the numbers line up again.
I have an 87 f150 and it does the same thing, when i took it to ford for oil change i told them 35,000 miles lol, guy looked at me n said what r u retarted add the 1 hundred thousand and my parents said the same thing.
You really can't go by the alignment of the numbers. Although, if the odometer has been tampered with, I understand there are marks that show up across the numbers horizontally to indicate that. Never seen one with them myself, so I can only go by what I have been told.
