Differential Noise
Differential Noise
Since I bought the truck last Sept. I have noticed a weird ticking/clicking noise under moderate to hard braking coming from underneath the rear of the truck. At first I thought it was the brakes or rotors. I had all 4 rotors turned and refinished and bought 4 sets of Wagner brake pads for each corner.
That didnt solve the problem. So I asked around and some said it might be coming from the differential. Well, last winter I noticed that my Trac-lok rearend wasnt working very well and noticed a considerable amount of uncontrolled wheel spin on the right side followed by a racheting noise inside the differential.
Today I went and bought some Friction Modifier at Ford today and 3 qts of Royal Purple 75w-140 gear oil and changed out the fluid. The old fluid looked fine to me. I also didnt notice any unusual gear wear or metal chunks or shavings in the bottom.
I just finished the fluid change and have not driven it yet so I hope that fixes the problem. I also noticed I have 3.55's and not 3.73's!!!
changing the rear end lube when 6 years old is a good idea. i cant see it helping your noise tho. limit slip clutch noise normally happens when turning. one hwell runs faster than the other... hopefully the bearings needed a good flush and new lube and it will hel?
mine will make that "clicking" noise whenever only one wheel spins, i think it has something to do with the clutches being worn out and slipping(i also changed my rear end fluid not too long ago) It has done this ever since i bought my truck.
Where did you buy your clutches at and for how much.
