Sponsored by: Auxito
what differential fluid do you use?
Old Jul 5, 2010 | 02:30 PM
guitarking135's Avatar
guitarking135
I'm going to be changing the fluid in both axles on my truck and I was wondering what brands you guys use. I'm considering Royal Purple given it's what I use in my bike and makes a very good motor oil. Also my front axle makes noise. Not really a grinding but kinda a tapping. I know a lot of 4x4's make noise like this but I also know a lot of them don't. I'm thinking it just needs the fluid replaced, well I know it needs to be replaced but any other thoughts?
Old Jul 5, 2010 | 03:12 PM
SteevenH's Avatar
SteevenH
Go with either motorcraft or mobil 1 ( full synthetic ). If you use motorcraft , make sure you
add 8 oz.(10.25 rear end) 4oz. ( 8.8 and 9.75) of friction modifier to the rear. 75/140 Rear. 75/90 Front. Mobil 1 doesn't require the modifier.
Old Jul 5, 2010 | 06:34 PM
guitarking135
ok which is better? I use my truck pretty harshly. I mean I pull trees out with it. and drive it quiet a bit so I want to use the best stuff that I can
Old Jul 5, 2010 | 07:11 PM
SteevenH's Avatar
SteevenH
I'm not an expert. I don't think you can go wrong with what came in it.
Motorcraft. That being said, I have mobil 1 in mine, only because I couldn't find motorcraft the day I changed it.
Old Jul 15, 2010 | 02:25 AM
Big Bad's Avatar
Big Bad
Red Line 75W-140, nothing better regardless of price.
Get it from the internet (ogracing, amazon, etc.) and it's actually cheaper than you can get Motorcraft or Mobil 1 75W-140 locally.
My next choice would be Amsoil Severe Gear, then Delo/Rotella/Schaeffer's Moly, then Motorcraft/M1/Valvoline SynPower, etc.
UNTAMND
Aug 5, 2010 12:48 PM
DrFord
Oil & Lubrication
18
Mar 22, 2010 11:47 AM
73cntry
May 18, 2009 09:36 AM
mitchrock1
Oil & Lubrication
Jan 18, 2008 12:20 PM
majorpecs
Mar 25, 2004 12:06 PM
