Modular V10 (6.8l)
Need help stopping V10 noises
Old Jul 25, 2007 | 06:19 PM
wfof250v10's Avatar
wfof250v10
Berryman Chemtool B12 works just like Seaform, I've used both and they clean the insides great. I've only idled the engine to clean it.
Old Jul 25, 2007 | 07:50 PM
Mr Incredible's Avatar
Mr Incredible
I used Auto-RX on my engine and had a very pleasant experience. It was not as bad as yours but it cleaned it of all the varnish and anything else that was visible under the valve cover and now everything is bright and shiny.
Auto-RX is a gentle cleaner that liquifies sludge and varnish over a 1500 mile period and then drained. A 2000 mile run of non-synthetic motor oil flushes the liquified contaminants away. If yours is as bad as you say I think an oil filter change at 1000 miles would be a good idea, too.
The website for further information is www.auto-rx.com . The Reader's Digest version is that ARX is made of lanolin esters that liquify the sludge like Dawn dishsoap straight up does to a greasy pair of hands, then the liquified sludge is rinsed away by the clean oil.
Again, it's a gentle operation over several thousand miles so you don't have to worry about big chunks breaking off and clogging anything up.
That, plus a switch to 5w-20, or at least a very thin 30w like Havoline Deposit Shield 5w-30, ought to do the trick. Wouldn't hurt to shorten your intervals to 4 or 5k miles after the ARX for the duration of the sludge removal.
Old Jul 25, 2007 | 10:21 PM
birkelbk's Avatar
birkelbk
Thanks for all the advice, folks. We'll probably take Ken's suggestion since that seems to be consistent with what I've elsewhere, oil change, Sea Foam, etc. I'll let you know after the second oil change.
Old Jul 26, 2007 | 06:24 AM
Big Orn's Avatar
Big Orn
I don't know what makes Sea Foam tick, but it's almost as good as moonshine...
Old Mar 24, 2008 | 04:33 PM
birkelbk's Avatar
birkelbk
Here's what happened...
We ran some Sea Foam through the gas and through the crankcase, but nothing has stopped the noises. We've had numerous oil changes, but that hasn't help either. The last garage told us that the noise is from the timing chains slapping on the housing and that they could replace them, but they'd basically have to tear down the engine. They tried to sell us a new engine because the current one is so gunked up. They suggested running BG Flush through it, so we said do it, but they changed their minds saying that it could blow the engine if the gunk clogged the oil pump, which would essentially require replacing the engine.
We're still at square one with the noises in the engine. Now we've had to replace the transmission because it wouldn't shift. The mechanic said it had self-destructed and bits of metal welded themselves to the inside of the transmission itself. This X is getting expensive.
Old Mar 24, 2008 | 05:38 PM
dkf's Avatar
dkf
It takes many years and alot of oil changes to clean out an engine. When I bought my 74' F-100 it was a little sludgy from little use. It took over 5 years and 25k+ miles to get it cleaned out. Honestly I think your engine has mechanical problems as well and is not just sludge related.
You can get a Ford reman 2V V10 and installation at a Ford dealership for around $4300.
Also I hope your transmission cooler was replaced or at least flushed real good before they installed the rebuilt tranny. The cooler will hold metal shavings, dirt and etc that will kill your new tranny.
Old Mar 24, 2008 | 05:43 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
It could well be the timing chains slapping - maybe the tensioner has gone bad, or the guides themselves are so grooved (and the chain is so stretched) that it can't take up any more slack.
Does it make this noise at idle?
Old Mar 24, 2008 | 09:20 PM
birkelbk's Avatar
birkelbk
Like you wouldn't believe. I think they mentioned something about the tensioner, too. They wanted $8000 for a new engine. It's been a real mess.
Old Mar 24, 2008 | 09:57 PM
msbweiland's Avatar
msbweiland
I agree, probbably the chains, could be from bad parts or lack of maintiance.
I've had excellent luck running a qt of ATF in my (and all my Ford fleet trucks) oil to help clean it out. My 99 V10 had 180K when I bought it this fall and after 6k and one oil change with 2qts of ATF in with FORD 5-30W, no crap and no valvetrain noise! My engine was full of gunk too. The oil turned black within 100 miles of driving after my 1st change. Now after teh 2nd it's gone 3500 and is still honey colored.
I can't imagine why someone would want to go 7500, let alone 10k on Penzoil! Hopfully it didn't have a FRAM filter too!
Good luck, looks like you're in for some $ or a new ride.
barrelhorses
Modular V10 (6.8l)
21
Feb 17, 2009 09:15 PM
Gage2502
Oct 11, 2007 10:02 AM
kenneBF250V10
Jan 21, 2005 07:43 AM
steve15375
Modular V10 (6.8l)
Jan 30, 2004 04:34 PM
Keith Smith
Exhaust Systems
Aug 15, 2003 07:51 PM
