Could be an IAC (idle air control) issue. This is what replaced the choke on carb engines. It could be cleaned due to carbon build-up...or just replaced. Not a very expensive part. TIP: Make sure to have an extra gasket in place...just in case the current one tears. IMO...it should be replaced...if the IAC is removed.
Here is a link in my gallery for a step-by-step removal and install. Plus part numbers if needed.
I had the same symtoms, changed the valve and all is good, seems to idle smoother too. I was going to do it myself but it was a tough reach at a tough angle for me so I paid my mechanic to do it. 1 hour labor for a part that goes bad every 100k miles is ok with me.
George
