engine test stand questions
Old Mar 1, 2001 | 08:32 PM
mike460's Avatar
mike460
has anyone ever built a test stand? i cant afford one, but i was hoping i could build one using some spare steel i can get ahold of. i wanted to know if i kept the transmission and engine together, could i use solid mounts(like fab my own) for the engine and tranny, or should i uses factory mounts? and i i dont keep the tranny on it, should i solid mount the back of the engine and the mount pads? its about to be spring break, cant afford to go to cancun with my friends...ill be bored...i have a 460 that needs to be finished, but i have nothin to put it in right now but i thought it would be fun to irritate the neighbors a little....any info would be greatly appreciated. thanks,
mike
Old Mar 2, 2001 | 07:28 PM
hpguy's Avatar
hpguy
This sounds interesting... might be fun to run my 600cid fire-breathing monster on when I'm done with it
-Andrew
f250_64(No Email Addresses In Posts!), same for yahoo messenger
Nothing, and I mean nothing, stirs the soul, saying I'm a bad **** like lettin'em rip with a window shaking, fuel gulpin, carbon monoxide belchin, attention gettin, V-oh my LORD!-8!
Old Mar 2, 2001 | 07:47 PM
billyb's Avatar
billyb
saw a guy who took the front frame section from an 83 f150 he got for nothing from a scrapper, welded legs with flanges on them, and bolted to a pad next to his garage.he had the section from about 4inches in front of front crossmember to just beyond the transmission crossmember.
he was a mustang nut, and would build and test the engines. had a radiator setup and temporary exhausts and all!!
Old Mar 5, 2001 | 09:33 PM
bb78bronco's Avatar
bb78bronco
I am in the process of building one for my 460 block. i put my motor mounts on and started from there. I bolted 1/2 inch flat steel to that. then welded a frame on to it with a rectangular base with steel casters. i am going to have a radiator mount on the front. i am going to use a bell housing from a 4sp and a heavy flywheel . this will allow me to mount the starter and ensure enough weight on the motor. very easy to build takes time, imagination, and a welder!!!
Old Mar 6, 2001 | 02:39 PM
mike460's Avatar
mike460
thanks guys for all the info. i guess i need to round a welder up and have some fun. thanks again,
mike
Old Mar 7, 2001 | 06:05 PM
ecarter50's Avatar
ecarter50
I found a nice one on ebay to copy even if it is for the wrong brand. http://cgi.ebay.com/ebaymotors/aw-cgi/eBayISAPI.dll?ViewItem&item=565931598
Old Mar 7, 2001 | 09:56 PM
mike460's Avatar
mike460
thanks man, those are some of the best photos of a test stand ive seen. thanks again,
mike
Old Mar 8, 2001 | 06:45 AM
DannyP's Avatar
DannyP
Really all you need is some angle iron, some flat steel, a drill and a welder. I cobbled together one years ago for Chevies, all it consisted of was 4 legs that bolted to the four corners. Crude but it served the purpose. With a Ford you will need a bellhousing if you are going to put a starter on it.
As a side note, a friend and I accidently started one without a stand, it was just sitting on the ground on its oil pan!!! Its been years ago so I can't remember the details, but for some reason we had hooked up a battery to the distributor on an engine we had just pulled, and I was turning the crank pulley by hand when the dang thing fired up, at an idle thankfully. It rolled over onto its side and we pulled the battery wire. Scared the crap out of us but it was kinda funny.
DannyP
89 F-150 4x4 former EFI I-6 now carbed 351W, Edelbrock heads,cam,intake,carb.
MSD 6A, ZF, Sterling 10.25 with 3.55L's.
Old Mar 8, 2001 | 10:11 AM
dre's Avatar
dre
Don't know how much money you are willing to spend on one, but PAW sells them for somewhere around $640.
give them a call.
Dre'
1978 F-150, 460ci(750cfm,Edelbrock Performer,Dynomax Ceramic Coated headers,etc.)Auto-C6,3:70.1 - 9" Posi.
Old Mar 17, 2001 | 06:45 PM
cbwarrior's Avatar
cbwarrior
My buddy and I fired up an engine setting on the ground before. All we did was leave the cherry-picker hooked up to keep it from flopping over. We didn't have anything to cool it, so it didn't run long, just long enough to show him it worked before he bought it.
88 F-150 4X4 w/5.0 EFI 5 spd
86 Ranger 2WD w/2.3L EFI 5 spd to be 351W 4bbl C4
Old Mar 19, 2001 | 10:04 AM
dterrian's Avatar
dterrian
WillyB
N. California Chapter
20
Jan 3, 2007 12:03 AM
justine's77ford
Jun 12, 2005 02:27 AM
Goodold71
Nov 14, 2003 12:30 PM
mike460
Mar 4, 2002 06:50 PM
mike460
Feb 17, 2002 11:03 PM
