what brand drop bracket is that? i will take a pic of mine tomarrow, its much beefer than that 2 piecer you got, mine is all one piece and has cross braces welded to it, i was wondering how you mangaeg to crack yours
Quick question about IFS.
I have replaced the ball joints and tie rod ends. I also have a quote of $380 to replace the pivot bushing. Does that sound correct? And are you all modifying this suspension set up to beef it up at all?
Or should I just leave it and it won't break for a long while LOL?
I noticed the lag dropped off a lot, after the intercooler it was significant lag, but now it's almost like it was before the intercooler, which is a lot faster.
Let me know what kind you have c00nhunter, I would def like to go to something that will hold up better. I think I'm going to call up rough country and see how much that bracket is, I was looking at it closer and looks like it would be better to replace the whole thing rather than fix all the cracks
mine is a skyjacker but i am just getting in so its a bit too dark for a pic session tonite, i will take a couple good pics tomarrow and post them for you
My lift is only 4" so I don't know if the 6" skyjacker setup would work..
My intercooler I bought off ebay, it's just one off a 99 SD, and I custom made all the mounting hardware, and cut to fit. I bought the pipes off banks since I didn't want to mess around making my own. By the way if anyone wants 4 pieces of 3" tubing bent to a 90deg angle I'll sell them to you cheap!! I was going to make my own, but just liked the banks pipes and ram air deal.
Well I called up rough country and just ordered a new bracket for the drivers side. $32 I figured I'll try a new one. Hope it doesn't turn out to be a PITA job....
