Intercooler MAP sensor bypass pics
Old Jul 24, 2007 | 07:27 PM
Pest007's Avatar
Pest007
here are some pics of my Intercooler bypass tube for the map sensor
Thanks to TJ
And my crappy broken bracket for the IFS
Old Jul 24, 2007 | 08:13 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Nice looking IC install. Take the IFS bracket out weld it up, plate it over to beef it up, then put it back in.
Old Jul 24, 2007 | 09:05 PM
c00nhunterjoe's Avatar
c00nhunterjoe
what brand drop bracket is that? i will take a pic of mine tomarrow, its much beefer than that 2 piecer you got, mine is all one piece and has cross braces welded to it, i was wondering how you mangaeg to crack yours
Old Jul 24, 2007 | 10:51 PM
Pest007's Avatar
Pest007
mine is a rough country 4"lift
Old Jul 24, 2007 | 11:10 PM
RubberDuck's Avatar
RubberDuck
Pest, I'm gonna do that as soon as I get the chance. Did it really take out alot of lag?
Old Jul 24, 2007 | 11:25 PM
Flea's Avatar
Flea
Quick question about IFS.
I have replaced the ball joints and tie rod ends. I also have a quote of $380 to replace the pivot bushing. Does that sound correct? And are you all modifying this suspension set up to beef it up at all?
Or should I just leave it and it won't break for a long while LOL?
Old Jul 25, 2007 | 09:35 AM
Pest007's Avatar
Pest007
I noticed the lag dropped off a lot, after the intercooler it was significant lag, but now it's almost like it was before the intercooler, which is a lot faster.
Let me know what kind you have c00nhunter, I would def like to go to something that will hold up better. I think I'm going to call up rough country and see how much that bracket is, I was looking at it closer and looks like it would be better to replace the whole thing rather than fix all the cracks
Old Jul 25, 2007 | 06:48 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
Nice looking intercooler install, where did you buy it: Banks?. is all from there or only the Y pipe and the other pipes.
other question: where we can put the "T" for the boost gauge in that configuration?
Old Jul 25, 2007 | 08:33 PM
c00nhunterjoe
mine is a skyjacker but i am just getting in so its a bit too dark for a pic session tonite, i will take a couple good pics tomarrow and post them for you
Old Jul 25, 2007 | 11:06 PM
Pest007's Avatar
Pest007
My lift is only 4" so I don't know if the 6" skyjacker setup would work..
My intercooler I bought off ebay, it's just one off a 99 SD, and I custom made all the mounting hardware, and cut to fit. I bought the pipes off banks since I didn't want to mess around making my own. By the way if anyone wants 4 pieces of 3" tubing bent to a 90deg angle I'll sell them to you cheap!! I was going to make my own, but just liked the banks pipes and ram air deal.
Old Jul 26, 2007 | 05:49 PM
Pest007's Avatar
Pest007
Well I called up rough country and just ordered a new bracket for the drivers side. $32 I figured I'll try a new one. Hope it doesn't turn out to be a PITA job....
Old Jul 28, 2007 | 02:05 PM
c00nhunterjoe
sorry it took so long
jamestheron08
61
Oct 23, 2013 08:20 PM
ATC Crazy
Virginia Chapter
Sep 9, 2008 11:44 PM
Snowking
17
Jun 18, 2008 09:42 AM
Snowking
42
May 20, 2008 01:16 PM
Storm
Oct 9, 2007 07:18 AM
